Puddle lights
Old Mar 22, 2005 | 07:23 PM
supraken's Avatar
Puddle lights
I noticed that many of the new cars have puddle lights in their side mirror, which shines on the ground to illuminuate access. I was thinking of adding an LED to the bottom of the mirror to do this (well, more for show than anything to me), but I have no idea where to get the power.
Ideally, it would be best to get power from the dome lights, since they light up whenever you turn off the car, and when you unlock the car. Does any one know if there's any portion of that wire that's close to the door? Or if there is any better power source already in the door?
Old Mar 22, 2005 | 07:38 PM
phile's Avatar
Pinky all stinky
Those aren't puddle lights. Puddle lights are the ones in the door, so that when you open it, it illuminates the area.
The lights you see on the side mirror that's shining down is actually to reflect off the metal, so that when a car is making a turn, other drivers viewing it from the side will know that it's trying to make a turn. It's basically the same concept as the TSX's side blinkers.
Old Mar 22, 2005 | 07:44 PM
Dan Martin's Avatar
Photography Nerd
You can probably access the power down by the fuse panel. Just look at the chart to find which fuse is for the interior lights.
You'll also need to add a resistor inline with the LED because 12v will be too much for it.
Old Mar 22, 2005 | 08:00 PM
phile's Avatar
Pinky all stinky
You're talking about lights that shine downward like the one seen here, right?
http://www.dieselstation.com/wallpap...haeton-023.jpg
Old Mar 22, 2005 | 08:10 PM
supraken's Avatar
ahh, good point... forgot about the fuse box...
hmm... not sure if I should do this as I'm good at taking things apart, but not putting things back together esp since I'll need to drill holes underneath the mirror....
Old Mar 22, 2005 | 08:12 PM
supraken's Avatar
Can't see the link.... access forbidden... but I'm pretty sure those things are called puddle lights, they shine onto the floor to show what you're stepping on if you get out of the car (e.g. puddles), hence the name.
Old Mar 22, 2005 | 08:23 PM
phile's Avatar
Pinky all stinky
I didn't want to post the pic because it's so big, but hopefully it works this time:
Those are not puddle lamps.
These are puddle lamps:
oyayjoe
Jan 1, 2019 10:17 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
oyayjoe
Sep 12, 2015 04:40 PM
Nicho863
Sep 2, 2015 08:12 AM
