plastic arm in the glove compartment
Ok, this is kinda embarrassing.
Last Sunday, after driving back from Atlanta, I drove to Tims Ford Lake (it was on the way) to go hiking ...
I needed something from my glove box so I opened it and stupidly let it drop like I always do. Because I had the new car warranty booklets in there plus some other stuff, it was a heavy drop and broke off the hook of the arm. I had only the arm to hold the glove box because I was going to change the cabin filter very soon and was too lazy to put in the two stoppers at either side.
Anyway, I called Acura today and the parts guy said what I described sounded like a 'stopper arm', however, he says there are TWO of them and they sell for $2.30 each. I only saw one so that can't be right. Anyone know what this is called?
Nevermind. The parts guy at Gary Force Acura faxed me a parts drawing and it looks like what they call a "Dampner", which comes with a cylinder housing where the plastic arm contracts into. It costs $12.65 and would have to be ordered in as they don't carry them in their inventory.
I guess it's not every day that this part get broken off
Let that be a lesson to others.
I just noticed that mine is broken as well. I do not know if I did it or the guy that serviced my car did it. I went to a regular quick lube place for and oil change, and the guy insisted on changing the cabin filter. I decided to change it my self and upon going to do so found the hook to be broken. Does anyone know where I could order this or have instructions on replacing it? I checked the acura online and was unable to find it.
I broke my dampener when i removed it to replace the cabin filter... It bothers me that it is broken even though it really doesn't affect anything. So this means i will be changing it soon! If anyone happens to find any info on how to get to it, please post! I probably won't do it until the Ohio decides to turn the snow machine off and warm up.
There aren't really any sites or stores that carry this for any cheaper than 8$ and change. Shipping is about 12$ across the board for ground. I think the best option is to go to the dealership and order one, they do not carry the damper on hand but you can ask them to order it for you. There is no shipping charge as long as you pay in advance at the dealer. It is about 15$. I'm gonna go with this option since there are two dealers within 10-15 mins of me. Also going to wait until this horrible winter is over.
i got a little creative with 3 zip ties and managed to connect them so it works. make a small loop around the shaft (small enough it wont fall off) and 1 thru the glove box shaft where the hook goes, then the final one connecting the 2 loops. wa-la and no need to order the part.
I think it's only two screws that hold the upper part of the arm in place. You bring the latch toward you to lock it in place to the glove box.
Quick search found:
#21, 77530-SEC-A01
http://parts.sonsacura.com/showAssem...chString=glove
12 bucks plus shipping (which is usually awful...just have your local dealer order it and you're often ahead).
#21, 77530-SEC-A01
After playing with it a bit, I realized it wouldn't work if just pulled like a typical cantilevered handle. I have to put my thumb on the lock cylinder and kind of brace it as I pull on the handle. Difficult to describe the motion - it's almost like you're pushing in on the lock cylinder with your thumb while simultaneously pulling on the handle.
I've gotten used to it now but still kind of silly. Doing some reading, I thought I found others complaining of this, so maybe just a bad design.
Have you tried opening it while pressing on the lock cylinder? Sounds stupid, I know. But when I first bought my '06 a couple months ago, I was sure it was broken cause no matter how much I tugged, it wouldn't open - and I didn't want to pull too hard & break it.
dirleton
08-06-2024 08:19 PM
mlody
12-04-2019 02:11 PM
dainmezron
10-16-2015 06:56 PM
adreano17
09-29-2015 08:48 AM
