Pinout for stereo harness?
Does anyone have a link to something that shows what each pin of the TSX audio connector does? I found the below, but if you look at the end, the colors listed in the text don't match the colors mentioned for the same pin in the picture....
https://acurazine.com/forums/showthr...harness+pinout
I know I should have posted this in the other section but it doesn't seem like many people look there...
Thanks for the extra diagram... but now there is even more confusion. The colors don't match, fine, but now the pinout doesn't match either... on the diagram I linked to, B4,B5,B6 is ground, r+ and l+... on the diagram you linked to, they are Front Passenger Door Speaker+, Driver Shielding, and Right Rear Speaker + ...
I can't seem to find which pins on the diagram you linked to are INPUTs ... all pins seem to be outputs going to speakers around the car.
I'm looking for the ground, left and right INPUT into the car's amp... anyone?
xsilverhawkx
09-28-2015 06:51 PM
4drviper
09-23-2015 09:00 PM
