paint pen question
registered user
paint pen question
Could anyone post any personal experience that they've had with a touch-up pen? I have some small scratches (through the clear-coat) on my nighthawk black pearl TSX that I'd like to try to fix. Btw, I tried using the search tool but I couldn't much hard information as to whether the paint pen is crap or not.
I understand that the touch up paint pen available in Canada is better. Its supposed to come with a paint tip on one end and a clear coat tip on the other. I saw a guy on e-bay selling those for somewhere around $13-$14.
Pearl White In E-Town
Yes the pen from Canada is better, Isn't everything better from Canada?...
Joking aside, yes the pen does come double sided. 1 side for paint the other for pearly clear coat.
From personal experience - the pen works great! It often takes a few coats to match it almost perfectly but its well worth it. I've even used it on large rock chips with good results.
You should be able to find them on e-bay
registered user
I got a little nail polish bottle of SSM touch up paint from the stealership for $6. They don't sell the pens at the stealership though.
My experience with using them is.....I used it on some rock chips and it pretty much looked like rock chips filled with Paint from a nail polish bottle. I think the spots were more noticeable once they were filled in so I ended up wiping it off right after I put it on.
I also saw the pens on ebay....I might have to try one of those instead.
send me a link to JDM??
TSX.fury who would just like to ask if anyone else has noticed CJams is all about the now
Originally Posted by Camden
Thanks, Nd4spd. Is there much risk of making the scratch look worse by accident? How do I distinguish this Canadian paint pen from its lesser USA version on Ebay?
Someone stole "My Garage"
If you could verify that it's base coat on one end and PEARL on the other, then I am a very happy person.
My local dealer won't order one in w/o prepayment, and I won't prepay w/o confirming this. LOL.
I got mine from my dealership. It is not an "Acura" brand pen but it's 19.99, I have a PWP so they gave me one entire pen for the PWP and another for the pearl. My friend got one for his NBP TL, and he only got 1 pen, apparently he didnt need it since the clear coat was pre-mixed although im not sure how that works. But hey, 2 pens(one paint 1 clear) for 19.99 aint not so bad
Originally Posted by jlukja
the difference is that the Canadian pen has two sides to it, one side with the paint, the other with the clear finish. The US version has just the paint.
Originally Posted by curls
Hey, regarding the "1 side for paint the other for pearly clear coat." ---> Do you mean that one side is, say, white base coat, and the other side is the PEARL coat? What color paint pen do you have personal experience with? I have been wondering about this -- I need a base/pearl pen but am not spending a TON of $$ to bring one over from the USA (paintscratch.com) - Worked out to $45 CDN for 2 pens + shipping.
If you want I can check with my dealer to see how much it was. If its alot of savings, I might be able to pick it up for you and ship it out East (they're pretty light so I imagins shipping wouldn't be expensive)
Hope this helps everyone who needs info on these pens.
Yes one side is base coat, hte other is pearl/clear coat. I've used the Premium White Pearl touch-up pen, and like I said before works fantastic! You shouldn't have to spend that much money to get it, I thought Canadian dealers should stock it. I got mine from my dealer in edmonton for $12 CDN (I think it was around there, I know it was less than $20).
Thanks!!!!!!!!!!!!!!!!
~Eric
TS-SEX
I bought my paint pen from Walmart. "Duplicolor Scratch Fix 2 in 1" product which has the roller ball pen tip and the brush. Cost me about $5+ and it worked great! They got the honda OEM colors, clear coat, and even primer. I bought a SSM and a clearcoat pen and it worked just nicely.
http://www.duplicolor.com/
Is it a Honda/Acura part? If so, can you give me the part number?
~Eric
~Eric
Okay the number is hard to read because its rubbed off, sort of faded. But as far as I can make out 1UOANH624P (this was the number under the bar code, its for PWP). It is a genuine ACURA/HONDA part. I called my Acura dealer and he said the pens only cost $11.35
Thanks a ton for the help!
~Eric
Just an update: The paint pens match a LOT better than the bottles. 100 times better. Although, they take longer to harden/dry (took 5 days to become 2000-grit sandable. So, be patient.
I just need to put the pearly-clear on top tonight and then wetsand again on maybe Monday (holiday). Then polish and pics will be posted.
