Nut cracker - has anyone used one?
2.4 L iVtec
I cant get the nut off the bolt on my stock swaybar. I tried everything and nothing seems to work. This is my last resort.
Has anybody used the nut cracker on this specific nut? I was curious to know if the bolt is too strong for a nut cracker, or cant it be? Will the nut cracker crack pretty much any nut? Do you guys think this one is too strong for a nut cracker?
I can't think of anytime I've run across a hardened steel nut before. Bolts, sure but no nuts. If you have enough room and a Dremel tool, it helps a lot to score the nut where you want it to split.
There is a lot of way to do this.Soak it down with WD-40,heat it up and pair of vase grip.U do know that you using wrench and hex key to unscrew it.Running a lot of problem like this when i fixing the car.Heat it up is the best way to do this.
cycdaniel
12-17-2019 10:58 AM
