Need new key and FOB
Old Dec 4, 2006 | 02:14 PM
BzeTSX's Avatar
Guys, I lost my original spare key and FOB. I was thinking about getting this one,
ebay but im not sure if i have to get the key itself programmed. Will the key work if i just get it cut at home depot or somewhere, or do I have to go to the acura dealer?
Old Dec 4, 2006 | 03:25 PM
CurryFishBall's Avatar
Nissin Ramen
I believe you will need to get one from the dealership...as they have some sort of chip inside the key...which is where the engine immobilizer comes in to play.
I think there was a bar code on a small strip of paper that came with your keys? At least in Canada.
You will probably need that to get the dealership to cut you a new key + FOB.
Good luck!
Old Dec 4, 2006 | 03:30 PM
BzeTSX's Avatar
so in other words, the key has to be cut from a dealer? what about the FOB? can i get an aftermarket one and program it myself?
Old Dec 4, 2006 | 03:42 PM
xizor's Avatar
Bye TSX, hello domestic?
the fob you can do yourself, the key you can cut, but it needs to be programmed which you cannot do. the key will open the doors and turn the ignition, but the chip embedded in the key will not start the fuel pump unless its programmed.
Old Dec 4, 2006 | 05:45 PM
Miamicarfan's Avatar
There is a chip inside the key???. It does not look like it.
Old Dec 4, 2006 | 05:54 PM
Alin10123's Avatar
It's there. It's for the engine immobilizer.
Old Dec 4, 2006 | 07:50 PM
moda_way's Avatar
I think someone hasn't see the key fob mod thread yet.
Old Dec 4, 2006 | 08:29 PM
Tampa TSX Girl's Avatar
Yep, you gotta go to the dealership. I recently had another key made. The dealership cut and programmed the key for about $40. Not sure about the key fob, though...
Old Dec 5, 2006 | 08:52 AM
alucardx's Avatar
key fob should be able to program yourself. i did this when i had my nissan altima '02. the dealer woulda charged $130 but i got one off ebay for $20 and programmed myself.
Old Dec 5, 2006 | 11:29 AM
BzeTSX's Avatar
Esserman want $50 for the key, $80 for the FOB, and $95 to program them!!!! Thats $225 plus tax for a spare key!!!! anyone have any suggestions?
Old Dec 5, 2006 | 07:37 PM
S14 n Tsx's Avatar
mmmmmm....
Old Dec 6, 2006 | 09:06 AM
BzeTSX's Avatar
dude so what if this guy hasnt seen the key fob mod yet??? that has nothing to do with my question. Where can i get a spare key that starts my car for less than $100.00??????????????????????? PLease someone
Old Dec 6, 2006 | 02:03 PM
kyotousa's Avatar
I might sell my key fob and you can get spare key from ebay then get it programed
Old Dec 6, 2006 | 08:34 PM
BzeTSX's Avatar
do i have to get it programmed at the dealer? They want to charge me $95 on labor for the program.
Old Dec 6, 2006 | 08:50 PM
JTso's Avatar
You can get a used remote off ebay ~ $25. The key and programming is around $150 and the dealer has to do it. Make sure to bring all your other keys in at the same time.
Old Dec 6, 2006 | 09:26 PM
Un-Kut's Avatar
can somebody explain why the programming costs $100??? wtf....
Old Dec 6, 2006 | 09:38 PM
kyotousa's Avatar
actually i meant i might sell my remote...
but you'd still need to get it programed......(I think you can program your own remote)
not the key fob.....dealer has to do that
or you can find lock key smith.....maybe they can reprogram it...
Old Dec 6, 2006 | 10:03 PM
xizor's Avatar
my suggestion, read the key fob mod, provide your valet key and cut the chip out of there for use in the Accord key, $50 and you have a brand new key, no programming needed
Old Dec 6, 2006 | 10:05 PM
xizor's Avatar
so the dealer can make money...
Old Dec 7, 2006 | 03:39 PM
BzeTSX's Avatar
screw that. ill just copy a basic honda key at home depot.
Old Dec 7, 2006 | 03:45 PM
JTso's Avatar
But that won't start your car.
Old Dec 7, 2006 | 03:50 PM
xizor's Avatar
you're missing the point here
Old Dec 7, 2006 | 04:11 PM
jlukja's Avatar
There are two seperate programming steps necessary:
1. programming the remote functions (door open/close, windows, trunk, panic). This you can do yourself
2. programming the unique chip in the key to work with the immobilizer. This the dealer has to do.
Old Dec 7, 2006 | 11:03 PM
Rocket_man's Avatar
Summer is Coming
Some locksmiths with the proper equipment can program the immobilizer in the new key to start your car. Yes you can get it cut just about anywhere, but until the immobilizer chip embedded in the key is programmed to the security system in your car, it won't start the car. You can try taking the newly cut key and placing one of your working keys next to the lock cylinder. The security system will read the chip from the working key and the car should start. Take the old key away and the car won't start. Then you will see the difference. If you want a dealership to do it, try calling a Honda dealer. They should have the same equipment and lower labor rates.
Programming the key _FOB_ is a whole different thing, that you can do yourself.
Old Dec 8, 2006 | 07:47 AM
BzeTSX's Avatar
ohhhkaay.... found this site, http://www.streetkeys.com/default.asp that should work
datadr
Mar 23, 2016 01:39 PM
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
malvothegreat
Sep 29, 2015 12:38 AM
