Nav Voice Volume Question
We took delivery of an 06 NHB 6MT with Nav Monday evening. We love it so far.
We've noticed, though, that if you have the stereo volume moderately loud, the navigation voice notifications are not loud enough to understand over the music, even at max volume. It sounds like the head unit mutes the front speakers, but not the back door speakers or the woofers. In fact, when we took delivery, the nav audio was too low to hear at all at highway speed. We almost took it in for service because the front speakers were cutting out, but I figured out it was the nav system trying to talk.
Is there a way to either tweak the nav volume max setting, or to have it mute all the speakers instead of just the front?
There is no way to "fix" this, that I'm aware of. When my music cuts out, I simply look @ the screen to see what I'm supposed to do next. Not an issue for me, in other words.
I assume you have already turned up the nav voice volume at the setup screen? The voice seems loud enough to me when it's near the maximum setting, but I also tweaked my balance and equalizer settings to significantly reduce the bass thumping out of the rear speakers (at least until I get some that don't sound like crap).
Oh, are you still running on stock tires, too? If so sell or ditch them and get some good quieter tires. Even ultra-high-performance all-season tires like the Avon Tyres Tech M550 A/S that I have on are significantly quieter (though still pretty loud over concrete) than the crappy stock Michelins. Doing this will reduce road noise, making the nav easier to understand, and allow you to lower your stereo volume, which will help even more.
Billy M
somewhere in the developers menu (menu, guide, cancel all together) there is a way to raise the volume further for each of the volume settings on the navi, so you could change the max volume to be much higher, if i remember correctly, you there are 250 levels and the highest is only at 180 or so, so if you bring that up to the max, you will experience it louder, when i get in my car tonight or tomorrow, i will check exactly how to do it and post back tomorrow
Originally Posted by Spy
I just tried this myself, but I didn't see where to turn up the volume. Is yours an 06?
Billy M
ok fellas,
here's how its done:
1. press map/guide, menu and cancel all together for a few seconds
diagnosis items will come up
2. press and hold menu again
the developer menu comes up
3. select volume setting
a list of numbers comes up, the highest for me is 230, it goes up to 255 and is significantly louder than 230 (which i think is default, or a little higher than default)
4. set the volume as loud as you see fit, number 11 is the highest setting in the setup menu, and number 1 is the lowest, with everything in between, i recommend makinf number 11 the highest then you can always turn it down when you are in a quieter environment, or have the music off
5. use the up and down buttons to choose the volume and the up and down arrows to choose the setting
6. you can test it with the test button (duh haha) then when you are happy, press save
7. press return three times and you are back at the regular menu, with louder volume than ever!
i knew it was possible, you can always reset it to the factory defaults through the same menus if you ever desire, good luck
AndrewS
19
03-14-2024 06:59 PM
BoricuaTL
04-08-2016 01:08 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
