My trunk is broken!
Old Jun 10, 2004 | 05:40 PM
justinnum1's Avatar
My trunk is broken!
I got to my car and went to open the trunk and it didn't open. Inittially i thought that the car was locked but it wasn't. I am talking about the black button above the license palte. I am able to open the trunk via the key fob and the lever by the front door. Does anyone have any ideas why this is malfunctioning? It is almost like the button died. I have sheduled my car to go in next week with a long list of problems. The reception lady thought i was nuts. Here are my problems. I don't know whether i am writing them out of boredem or not.
Left drivers window chafes the window sill when opening and closing.
The trunk problem.
Driver seat moving foward under breaking.
Ext. temp display is broken.
Tiptronic does not register some downshifts.
Drivers door makes a weird creak when opening.
Rear deck speakers pop.
The ignition takes to long to start the car.
I asked the reception lady if i can have the new TL for a loaner and she said only if your car is here for longer then a day. I was like"did you here nay of the problems i said"?
Old Jun 10, 2004 | 05:50 PM
Bass Mechanic's Avatar
well you have to unlock ALL the doors by pressing the fob 2 times to unlock all doors. or pressing the unlock button on the drivers door before the trunk will open. otherwise what is to keep people from walking by and opening your trunk?
no need to take it to the dealer , it's operator error.
Old Jun 10, 2004 | 05:56 PM
justinnum1's Avatar
Negaitve bass. Operator knows exactly what he is doing. I pressed unlock 5 times, went into the car and pressed the unlock button on the drivers door and it still did not open. I would not waste other peroples time with a problem that could easily be fixed.
Old Jun 10, 2004 | 06:01 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
Hey [justinnum1]...don't worry, your trunk button above the license plate is not broken. I had the same problem before, but it was just a switch that wasn't turned on at PreDelivery Inspection. The switch that I'm talking about is in your glove box. Open up your glove box and at the very top of the inside is a switch, you must croutch down to see it or just feel around for it. Most likely, this switch is in the "OFF" postion, all you have to do is switch it to the "ON" position and your black button should work fine. I actually like this option of being able to disable that button. But yea...the fix is as simple as that. Hope that helped
Old Jun 10, 2004 | 06:41 PM
justinnum1's Avatar
TSX 3pedal, thanks but this is a car that is a year old and that soultion would not apply here. I tried your advice anyways and was unsucesful at fuxing the problem. Also when i press the unlock butting whether in or out of the car i dont here an unlock from the trunk are and o thought i use to here one? I think i have a major problem here. Any advice?
Old Jun 10, 2004 | 07:35 PM
oops, sorry, are you sure your car doesnt have a switch in the glove box. well actually i belive it is just outside the glove box opening under the actual door of the glove box.
try sitting in the passenger seat when looking for it. if i recall its hard to see from the drivers seat.
try giving it a press turning it on and off a couplke times and leave it in the on position.
EDIT: ok i just looked and i was right that switch is high upinside the glove box, you almost have to lay your head on the passenger seat and look up. it says MAIN on it. and slides left to right. try that... let us know
Old Jun 10, 2004 | 07:59 PM
slo007's Avatar
Master in Science
Any advice?
Pass by the dealer.
Old Jun 10, 2004 | 08:49 PM
xizor's Avatar
Bye TSX, hello domestic?
people use the button to unlock the trunk!?
Old Jun 12, 2004 | 08:20 AM
iamhomin's Avatar
04 remembrance
Hey justin, it's funny how you mentioned the rear speakers popping, because around a week ago, I was driving down the highway only to hear loud abrupt "construction" noises. After observing why the sound was persistent when I was driving nearly 70mph, I stopped the car near a gas station and noticed that the rear left + right side were popped.
But the problems went away once I restarted my stereo, however it's disturbing to know that it could reoccur.
Old Jun 12, 2004 | 09:27 AM
sixspeed's Avatar
That's actually normal. I usually pause the key at the "ON" position for a couple seconds for the fuel pump to kick in so that the starter wouldn't have to grind too long.
Old Jun 14, 2004 | 08:18 AM
Soupy's Avatar
6th Gear
There's a button to unlock the trunk?
Old Jun 15, 2004 | 04:19 AM
accsuperstar's Avatar
on your remote?!?!
Old Jun 15, 2004 | 06:36 AM
miner's Avatar
Under the back license plate lip there is an outside button to open your trunk. RTFM.
Old Jun 15, 2004 | 08:26 PM
hondaboy_tsx's Avatar
A-TSX Driver...
[QUOTE=justinnum1]...I think i have a major problem here...QUOTE]
Naww. It'd only be a major problem if you were in the trunk!
Old Jun 15, 2004 | 08:51 PM
ange1's Avatar
u see the keyhole at where u nobs for boot and fuel door is? maybe that's locked
Old Jun 15, 2004 | 09:35 PM
cmf's Avatar
cmf
ATCer
what's a nob for boot? ...
Old Jun 15, 2004 | 09:41 PM
djtrancetastic's Avatar
Battousai the Manslayer
[QUOTE=hondaboy_tsx]
Nah they have that unlock lever inside the trunk he could get out...
Old Jun 15, 2004 | 10:21 PM
TSX 3Pedal's Avatar
I think "boot" in Australia means trunk...
Old Jun 15, 2004 | 11:06 PM
cmf's Avatar
cmf
ATCer
I would have never guessed that in a million years, but it makes sense.
baelim
May 10, 2018 09:53 AM
dainmezron
Oct 16, 2015 06:56 PM
polish_pat
Sep 30, 2015 12:22 PM
juanrl
Sep 29, 2015 03:25 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
