maintenance interval reminder
Old Oct 30, 2004 | 01:39 PM
pandimus's Avatar
just looking over my shiny new 05 brocure, and it says there is a maint interval reminder. It is obvious what this is, but how does it work? do i set it, or does it remind me when there is a dealer specified check?
Old Oct 30, 2004 | 02:21 PM
biker's Avatar
Like all Honda's since the 90s a MAINT light that comes on (some higher end models have a milage counter) that needs to be reset every so often (milage depending on model). Basically an idiot indicator for those folks who don't bother to keep track of maintenance. And unfortunately you can't set it.
Old Oct 30, 2004 | 02:39 PM
brett's Avatar
Yes you can. You hold down the odometer reset button for 10 seconds while the ignition switch is turned to the second position. Its on page 68 of the US owners manual.
Old Oct 30, 2004 | 03:44 PM
pandimus's Avatar
how does this reset it? what i mean is does it count down from 3000 or somehting?
Old Oct 31, 2004 | 02:40 AM
biker's Avatar
That's a RESET not SET. You can't set it like an alarm clock to go off at say 3500 miles from now.
Old Oct 31, 2004 | 08:09 AM
brett's Avatar
Excuse me, my mistake. Yes, you can only RESET it, not SET it. Unfortunately a lot of people (who don't read their manuals) are under the mistaken impression that they have to take the car to the dealer to RESET the maintenance light. It would be nice to be able to SET it, but I can keep track of 5000 mile increments pretty easily in my head.
Old Nov 1, 2004 | 01:44 AM
biker's Avatar
Those are the same people that trade in their cars with the owners manual still shrink wraped.
Old Jan 2, 2005 | 08:19 PM
ImportsRhot's Avatar
Hey guys, I know this is an old post but i need ur help, i CANT RESET my MAINT Indicator and it's driving me crazy!! I read the manual, but can't get it to work. Last time I had to bring it to the dealer, and THEY couldn't even reset it at first, then I called the Acura Corporate and they made the dealer turn it off for me. SO i'm just wondering if i'm the only person having this problem or is anyone else experiencing this problem too? And if there is a fix?
Old Jan 3, 2005 | 03:55 AM
biker's Avatar
Sounds like something is wrong with either the dashboard switch or the ECU. Can you reset the trip odometer? I assume that if you can do that the switch is good and the problem is in the ECU. The dealer probably has a way to reset the light directly via the ECU connector with the diagnostic tool (a la BMW). If the reset of the light is done by some easy method (like BMW where you touch 2 pins together) then you could do it yourself - otherwise you'll be going to the dealer everytime to get rid of the light. Acura would probably rather have you come in and have them reset it for you everytime instead of giving you a new ECU.
Old Jan 3, 2005 | 09:46 AM
thanks biker, this is so frustrating!!
Old Jan 3, 2005 | 11:43 PM
poltergeist's Avatar
The maint. light is not triggered by the ECU, but by the Gauge control module in the inst. cluster. There's no way to clear the light besides the procedure in the owners manual (the HDS tablet that your dealer has will not clear the light, nor is there any other short connector or such in the car). First question...do you have any non stock electrical loads that come on when the key is at "run". Make sure you aren't leaving the parking/headlights on while trying to clear the light. If you have some type of non-stock electrical load, you'll likely have to disable it to get the light to clear. Also, make sure you're following the procedure in the owners manual exactly. If it won't clear and your car is stock, the dealer should replace the inst. cluster with a new unit.
Old Jan 4, 2005 | 06:32 AM
biker's Avatar
Originally Posted by poltergeist
The maint. light is not triggered by the ECU, but by the Gauge control module in the inst. cluster. There's no way to clear the light besides the procedure in the owners manual (the HDS tablet that your dealer has will not clear the light, nor is there any other short connector or such in the car). .
Then how did the dealer reset the light?
Old Jan 4, 2005 | 05:36 PM
Great news guys, I fixed the problem. I tried doing it with my HIDs off and it worked! I did it when the HIDs were on before because it was nighttime and I always leave my HIDs on at night even when i'm not driving the car. So thanks Poltergeist (and Biker for taking ur time). What's funny is the dealer couldn't even figure it out when i brought it in before.
Old Jan 4, 2005 | 06:35 PM
No problem...glad to help.
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
Skirmich
Oct 1, 2015 12:59 PM
