K&N air filter
Let me help you!
k&n was/is really popular. But all of my k&n filters look as if they let alot in (if you look up close, you can see through the holes in the filter). k&n even says that the filter works best when it's dirty (I guess it plugs up some of the holes?)
On my accord, I see crap in my intake pipe...I have to dust it off from time to time. I'm not going to ever put one on my new TSX. There's a different company that makes better filters, but I can't remember the name off of the top of my head.
I suppose k&n is popular because it's less restrictive (which implies it lets alot go through it). More power = excited people. If I was still into power, I'd do k&n. But now I'm into prolonging engine life.
I had on for my tsx but then I got a CAI. When I had to clean the filter I noticed nothing in my intake. If you want I can sell you my K&N air filter with cleaning suplys. Just send me a privit message and I will get back to you.
You're going to get mixed views about K&N. Honestly, I do NOT recommend them. Why? Because of the efficiency of the filter and the potential to over oil and damage vital intake sensors. Everything comes with a cost in life, and the K&N filter comes at the cost of risking more dirt in your intake because it doesn't capture as good as the OEM paper and the fact that often times some people over oil their filter when cleaning it. Even just the fact that the filter is oiled and you have a flow of air going through this filter that is covered will oil, creates the potential for oil to get into the intake and cover critical parts like a MAF (which happened to me in another vehicle and to my friend's Ford Lightning).
_________
I really like your reply, you're thinking is exactly like mine. ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
By the way, are you thinking of "Trueflow" foam air filters?
_________
I have been using k&n filter in my TSX for the past two years, but I do not re-oil it, just replace it once a year. I drive @ 20,000 miles/year and my TSX has 62,000 on it, average mileage 28 mpg, I did not notice any problems with the TSX.
Let me help you!
Well, after looking up Trueflow, I saw some stuff that reminded me of what I had been thinking of...Amsoil.
But from the quick searches, I've found that True Flow is more popular than Amsoil now (apparently Amsoil is contracting out the work, and the quality is worse?)
Although, by doing the search, I found a website that makes me wonder if I'll switch to a foam filter...
According to Bob is the oil guy :
Originally Posted by Bobistheoilguy
Foam is foam no matter who makes it. Fiberous filters are still fiberous filters, and paper is still paper. Sure there are minor differences, but in this test a clear pattern emerged based on basic filtration media rather quickly
Well there is a clear pattern on filtration ability compared to both flow and the type of filtration media used. The "high performance" cotton gauze and foam filters do not filter as well as some have claimed.
The poorer flowing filters, remove more particles, and the better flowing filters remove less particles. If you think about it, that conclusion passes any and all common sense tests, so it is not surprising. There are many that will be shocked by the results, that should not be though. I've used high performance filters in the past, and I might again in the future. At the same time, I know that the stock OEM type filters perform very well in filtration and don't inhibit flow nearly as much as some think.
Originally Posted by jlukja
So you buy a new K&N filter every year?
Yes, $30/year is not an expense worth worry about.
Someone stole "My Garage"
Recovering SUV Addict...
Originally Posted by curls
You realize that K&N's supposedly filter BETTER with age, right?
I found this off the Temple of Vtec...
http://www.duramax-diesel.com/spicer/index.htm
Much more quantitative and qualitative than Bob...I'm more inclined to believe this than anything. However, it's once again a short term test.
I've stuck with stock filters for years...until my '03 trailblazer, which I threw a K&N filter into. I did notice a louder exhaust note, but that's it. I have a friend who builds engines that swears by the K&N filters...but I'm sorta sitting on the fence. In the end, I almost don't care...
BTW...the "5 minute edit window" on this board eats my ass.
rcs86
08-02-2016 06:52 PM
