important tinting question!!
Old Oct 18, 2003 | 09:17 AM
NJtsx's Avatar
Automobile Aficionado
Ok....just got my car tinted and i waited 5 days untill i opened my windows but now there is a problem. Does anyone know if the little gliding lip in between the door panels(the part that holds the glass as it goes up) is suppose to be facing up or down? I dont remember what it looked like before. Because now half is up and half is down and it is causing a bunch of fine scratches all over the tint
Someone help....and if the supposed "awesome" place for tinting, screwed this up....im gonna flip. basically i need someone to post pics of their door where the window rolls up from the panles so i can see what the hell is wrong here.
Old Oct 18, 2003 | 10:02 AM
leftride's Avatar
i want to ride my bicycle
I will be putting my body kit on today, I will snap some shots of the window sill. Hopefully you can wait a few hours.
Old Oct 18, 2003 | 01:09 PM
b0h's Avatar
b0h
weee!~
from experience, it's supposed to be up...
the tint shop pushed it down, so they could tint the very bottom of the window...
usually they push it back up, or when you move the window, it automatically pulls it back up
Old Oct 18, 2003 | 01:37 PM
junk5681's Avatar
For those of you who have tinted the rear window, do you think that it is possible to remove the tint without destroying the defroster? My salesman informed me that this is a $500 repair.
Old Oct 18, 2003 | 02:05 PM
b0h's Avatar
b0h
weee!~
of course it's removable, but there is a great risk of breaking the defroster lines!
$500 bucks should ensure that it's a safe removal
why remove?
can't see properly - or was the tint a bad job?
Old Oct 18, 2003 | 02:24 PM
tony4311's Avatar
I am Ahab!
Re: important tinting question!!
why would you flip out. Everybody makes mistakes. If you go in there and flip out your going to get A LOT less help then if you went in there understanding.
Old Oct 18, 2003 | 03:07 PM
junk5681's Avatar
why remove?
No, I haven't even tinted yet. I'm just worried that if I don't like it, it will cost 5 bills to remove it.
Another question: For those of you with illegal tints, how often are you pulled over for it? In my state it is illegal to tint the front-side windows. I think it might look weird with only rear-sides and rear window tinted.
Old Oct 18, 2003 | 03:08 PM
junk5681's Avatar
Re: Re: important tinting question!!
I agree. Flip out as a last resort.
Old Oct 18, 2003 | 05:06 PM
majormojo's Avatar
such a dirty birdy
Originally posted by junk5681 Another question: For those of you with illegal tints, how often are you pulled over for it? In my state it is illegal to tint the front-side windows. I think it might look weird with only rear-sides and rear window tinted.
It might look weird or it might not. Around here, tinting the front sides is not permitted at all, and there is no restriction on the rear side & back glass, so you see a lot of cars with very dark tints on the back and rear sides, nothing on the front. You get used to seeing it and it doesn't look so strange.
However, I also see a lot of cars with tints all around and in fact that's what I did. Nothing too radical, I put 35% on the sides, 20% on the back window. It's not overly dark and especially with the sunroof open, there is enough light inside the car to identify the driver from outside. I had a conversation with a cop about this issue a couple years ago, and that is the real concern - if the tint makes it hard/impossible to identify the driver, there is a problem. Otherwise, they have more important things to worry about. It's one of those things that if you get pulled over for something else and give the cop some attitude, you'll probably get written up for the tint as well, but it's not usually an issue in itself.
Utlra-dark "limo" tint all around would be inviting trouble, not to mention just plain dangerous.
Old Oct 18, 2003 | 06:54 PM
junk5681's Avatar
Good info, thanks... I think I'll go for it and just roll down the windows when a cop pulls up next to me.
Old Oct 18, 2003 | 10:10 PM
ucsdtriton's Avatar
taking window tint off is not complicated but can be a time consuming hassle. I've taken window tint off the back and side windows of my old 89 Acccord Coupe Se-I because they started to turn purple (old films sucked).
Basically all you need to do is start to chip an edge off and then peel, if you do it carefully it mostly peels off in one piece. After you've peeled the actual tint off, there's the glue residue and remaining little pieces of tint. Just spray on lots of soapy water and scrape with a razor blade, and when you get too close too the defroster lines, you can rub the glue off.
AND, if you do happen to scratch off part of defroster line, no worries, (I did it), you can buy defroster repair kits. Works like white out.
Aug 15, 2019 12:58 PM
TLDude876
Dec 28, 2016 03:18 PM
Rocktman1
Oct 31, 2015 02:33 PM
wb2ee
2G RDX Problems & Fixes
Sep 22, 2015 12:00 AM
datadr
Sep 12, 2015 09:12 PM
