I get a free Accessory. Help me Pick!
Originally Posted by gfxdave99
i would get them fixed, let it heal and then get a clear bra...
I know that the clear bra is popular and probably protects well. Right now i do not have the cash for it. And i'm unsure because of how perminent it seems to be. (can it be removed?)
What are the risks and down sides of this solution?
Similarly i've heard that the nose mask also has downsides (other than looks). Roomers of scratching and mungyness if you don't remove it every once in a while. Is this all true?
Whats the best way to protect?
the clear bra is not permanent. you can remove it later on if you dont like it by using a hairdryer/heat gun. i think the risks of this solution is that some ppl say the clear bra material might turn yellow. but i've had mine for almost a year and no yellowing at all. also, i think there is a 5 year warranty on the clear bra material so that should pacify some of your worries.
personally i went with the clear bra because you can hardly see it and you dont have to take it on/off like the regular car bra
Originally Posted by dabuda2004
... personally i went with the clear bra because you can hardly see it and you dont have to take it on/off like the regular car bra
Did you get the x-pel? 3m? something else?
i found my installer on x-pel.com...i believe they use 3M material
Jamus22
06-11-2023 10:08 AM
calrow
05-03-2017 10:21 PM
ExcelerateRep
10-14-2015 08:20 AM
