Hydrolocked earlier
Hydrolocked earlier
I was on my way to work and anyone living in NJ knows it was pooring earlier. I was on I95 2 mins from G Washington bridge. The traffic was backed up and I was barely moving. Everyone was going through a couple puddles I went through about 3 so far. As I was about to go through another one the traffic seems to have backed up. As I was sitting behind a 16 wheelers I started noticing that the water was rising at a high rate and before I knew it boom. My engine seized and my heart stopped. I could not beleive that it happened. I ended up getting towed back home which cost an arm and a leg since very few tow companies are allowed to tow on on turnpike/i95. Its obvious what happened my Injen sucked some water in. What do you think I should do? Should I even bother calling acura and getting it towed to the dealer? Seems like Acura warranty would have nothing to do with it. I have full coverage with Geico, would they care that I have a CAI ? Should I put the stock intake back on? The worst part is that about 20mins later all the water went down. Why couldn't I have been very late to work today. I appreciate any advice you guys could give. Any negative comments please keep them to yourselves.
Thank You
Thank You
Just dial 1911
1 Post
Wow, this is a first. Dosent sound like they were "puddles" you were driving through...
What happens now when you try to start it? Its possible all it needs it just to dry out a bit. Considering you were just sitting in traffic, I cant see why there would be that much water taken in...
When I try to start it nothing happens. I dont hear the engine crank or anything. It was very hard to tell how deep it was but everyone around me seemed not to be having any problems. I think I got unlucky because same time it happened to me a G35C in the local lane died and 3 guys in a passat got screwed as well about 2 mins after I did. They are the ones that acctually pushed my car out of the water. So should I hurry up and get it to a mechanic or should I let it sit for a while to see if it dries up?
Just dial 1911
1 Post
Check main fuses and such too. If you have a stock intake, then hydrolocking is pretty much not going to happen. It would have to be above the front wheel to reach the first junction of piping where water could get in. However, you could hit some pretty decent wires with electric running through them.
where is my garage?!
1 Post
yikes. there was about 2 inches of rain on my street during the hardest part of the downpour. i hope it stops and clears up tonight so i can at least move my car for street cleaning.
did your injen have a hydroshield/drycharger on it? how deep was the puddle?
6th Gear
Originally Posted by moda_way
Sounds electrical to me. Maybe you didn't hydro lock rather you eletrically shorted and the bang you heard was the motor coming to an immediate halt.
if the piston tried to push water something has to give. most likely something internally is broken and is not allowing the motor to turn over or crank.
call your insurance company and go from there.
Does the elec system function at all?
If all your elec is toast then it is a fuse or short problem. If some elec works then it is possible that the fuse for your starter is blown. If that isn't the problem then you might be in trouble. Given your description I find it hard to beleive that the car would hydrolock that easily. My bet is that it is an elec problem at some level.
CL9 ABP
Damn you were in that rain too, I turned around and said screw this... Poor car couldnt bare it anymore. I took all those mild puddles slow. As soon as a saw water shoot up from the car in front I went to a really slow speed to pass it...
I have a hydroshield but todays rain was ridiculous. Hopefully it seems like electrical.
1 Post
any of you guys ever go into neutral and coast through puddles?
lol. i was actually thinking of getting a k&n typhoon and ditching the icebox. hearing this makes me think otherwise.
All the electrical works fine. The puddle was maybe 6-8inches when I went in it but like I said I was stuck behind a truck and the water was rising so I was have no idea how deep it was. Once I started moving again is when it hydrolocked. I saw other cars around me going just fine. Civics, old camry's just blowing by like it was dry pavement. I found it very weird as well the it hydrolocked. I live in a flood zone and i drove my car through deep water with problems before hence why I proceeded to through. So whats my best bet to call Geico or to call Acura? Should I even waste my time putting the stock airbox on? Could Geico deny my claim due to the CAI? Thanks everyone I really appreciate all your help I have no idea what to do since I have never heard of anyone actually hydrolocking their car.
Rep'n Taxbrain.com
If you plan to go through insurance or Acura, put your stock intake on. Better to be safe then sorry.
Don't try to turn the engine on. I would drain the oil and go through a couple of oil changes to try to get the water out of the engine. This happened to one of my neighbors once. He let drain the oil right away, and let it drain overnight to try to get as much water out as possible. And the engine ended up firing up after a couple of days. Then he did 2 or 3 oil changes. Good luck man.
If you have heavy rain, I would just switch the Injen to short ram mode. The few extra hp is not worth it in your situation.
1 Post
Thank You
Thank You
Is waiting in
this happened to my brother this morning in his 95 accord + AEM CAI on the Belt Pkwy. Luckily for him his car still starts, he waited for the water to dry out before he drove though. If his engine was messed up that just meant time for an H22a swap. Lucky for me I still have the stock intake, or i would have hydrolocked during May.
Be careful with trying to start it, if you try for to long you will distroy the starter for sure. Something in the startup process has to give, and as water does not compress AT ALL, the starter will break. If you haven't killed the started yet you can take out all of the spark plugs and try to start the car. If water is in the cyclinders than some of it will come out of the whole where the spark plug was. THIS WILL NOT FIX IT, just prove that it is indeed hydrolocked..."looking" for water through a spark plug hole will prove to be difficult. After that, put you stock air intake back on and make a claim with with Acura or Geico.
Have camera, will travel
Yikes! I just had a CAI installed and I live in Washington. I will be driving carefully in the rain.
Sorry about your car. That really sucks.
E92
Is this a big problem with CAI's? Im about to install the Injen with the hydroshield this saturday and live in about the same area (with serious rains here and there although I usually pull off and get a slurpee till they pass) so should I have much to worry about?
Rep'n Taxbrain.com
Did your gear safety lock engage? Not sure if you have a 5AT or not, but if it did, it will lock your shift gate and you have to insert a key in the shift lock.
I ask because this would be an indicator of a blown fuse. I would hope this is the scenario as it is better than hydrolocking from CAI.
Good luck, you never know, it might not be as bad as it could be.
Either way, I try to assess mods that are available. As much as I appreciate the knowledge and advice I get from car enthusiasts and forum experts, I try to keep reliability of the car and stay away from mods that contradict what Acura engineers have designed with a purpose.
And the CAI is a risky setup I have always thought. Especially being in Seattle which rains like cats and dogs here.
E92
Yeah we have some pretty good rain these months, I guess I'll just have it in cai mode for a few days till its supposed to rain, then convert it over. Maybe I can make a mesh shield for the bottom too, to keep water out, or something
damn sorry to hear about that man. hopefully it works out
this is why i kept my injen in short ram mode. i just didnt wanna deal with the possibility of it messing up my entire engine. Yes sometimes when its very hot outside the car does drag because of the heat in the engine bay but i guess its a safer way
Originally Posted by CGTSX2004
Keep in mind that if you take it to the dealership and they find water in the motor, they are going to be questioning you and may deny you a warranty repair.
Be prepared to make a comprehensive claim with Geico and see your rates go up.
Originally Posted by Simba91102
Why would Acura cover this as a warranty repair whether it has stock intake or not? Remember what a warranty is. Defect in parts or workmanship? With water in the engine? Unlikely. If you can stick the insurance company with it (and according to a post here you should be able to), I'd take the money and run (and reconsider the cold air intake on the new engine).
kest/ 05 TL
My girl works for allstate and told me that there were so many cars that they totalled out they went into catastrophe mode. Put the stock intake back in and call your insurance company.
definitely not puddles here in ny, the grand central parkway was also flooded today.. as well as utopia parkway.. flood also closed down 34th street and all of the green lines (4,5,6) were shut down
o wow. hope your car is oK. Im about to put on a CAI too. Dont know if i should keep it or not. sounds pretty risky to me. but SF barely rains so I don think i should worry much about it.
E92
Originally Posted by Tsx6363
oh and whats the diff between CAI and short ram mode?
