How to make the brake more sensitive?
Old Jun 3, 2009 | 06:31 PM
fanbanlo's Avatar
I've already bleed and flushed my brake fluid, but seems like it takes quite a bit more effort to stop the TSX compare to an Accord.
Any aftermarket part that can make the brake more sensitive? As in... require less distance, and driver's effort, to bring the car to a complete stop?
Thanks!
Old Jun 4, 2009 | 09:19 AM
Audioserf's Avatar
boost owns
Stainless steel brake lines significantly improve pedal feel. You might also want to add a set of quality brake pads (Hawk HPS come to mind). Contact Excelerate (one of our vendors on the Group Buys forum) for parts and he'll take good care of you and will be able to answer any questions you may have.
Old Jun 4, 2009 | 01:57 PM
bluecarbonfiber's Avatar
WTF?
what order did you bleed the brakes? according to the helms it says to do the front left instead of the right rear ( like normal cars ) not sure if that was a typo on there part or what.. also not sure if there is an acura dealer mechanic in the forum that confirm which is truley correct
Old Jun 5, 2009 | 10:11 AM
SirBLaughs's Avatar
i-vtec soo good
Thanks!
Brake master cylinder swap of a 7th gen. Accord? <---if that's the generation Accord you're talking about, then i know the feeling; "oversensitive brake pedeal that snaps passenger heads at every red light lol"
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
02tljj
May 2, 2019 08:56 AM
HOWELLiNC
Oct 19, 2015 03:26 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
