High Beam Bulb Code
Old Sep 6, 2004 | 01:29 AM
gocubsgo55's Avatar
101 years of heartache...
High Beam Bulb Code
I know this sounds kind of hard to believe, but after searching far and wide and doing everything but talking to the dealer itself, I still can't find the High Beam the TSX has. My guess is 9005, if not h1, but I want to be sure before I purchase a pair of hyper white halogen bulbs that will match the 4300k HIDs. Help is appreciated, I didn't get any in a related post. Again all I'd like is the bulb "Type" or "Code". Thanks.
Old Sep 6, 2004 | 01:33 AM
sigmachi96's Avatar
A-spec Arctic Blue
Hmm, you sure you did a search... this was just posted recently on another thread.
Highbeam is H1
Old Sep 6, 2004 | 01:40 AM
tony4311's Avatar
I am Ahab!
It also says on the headlight itself.
Old Sep 6, 2004 | 01:56 AM
gocubsgo55's Avatar
hmm. As for the search, I did search "headlight code", "high beam", and "high beam application guide". But I didn't take the bulb out all the way in order to see the H1. Thanks for the help. I still can't believe I couldn't find it in the owner's manual. Is it even there?
Old Sep 6, 2004 | 01:19 PM
JeffTSX's Avatar
Subie Tech
When I tried to change my highbeam blub, I also couldn't find the code in the owner's manual.
GHEY!!
Old Sep 6, 2004 | 08:34 PM
uilani158's Avatar
i just changed my highbeams to xenon hyper whites...the bulb size is H1...they look so much better than stock =)
Old Sep 7, 2004 | 10:28 AM
Bananaairsoft's Avatar
Sorry about the tread jacking here. For Canadian TSXs. the high beam lights also act as daylight riding lights at lower power setting. I hated the yellowish DRL and I tried a few different H1 bulbs. The aftermarket bulbs' color are very bright and white at full power ( hige beam) but just as yellow as OEM bulbs at DRL setting! Did anyone found an aftermarket bulb that gives nice white color at DRL setting?
ExcelerateRep
Sponsored Sales & Group Buys
Jan 6, 2016 09:59 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
theinsvnity
Sep 10, 2015 10:22 PM
HeloDown
Sep 8, 2015 06:51 PM
