HFL Trick i found.
Old May 28, 2010 | 03:59 PM
Lexusconvert?'s Avatar
HFL Trick i found.
I just found out that if you press the on the hook button for a few seconds the HFL goes into diagnostic mode and a voice with a british accent will say system ok then an asian voice says the same thing in japanese. Not sure if anyone else knew this.
Old May 30, 2010 | 10:44 AM
fast1's Avatar
What hook button are you talking about?
Old May 30, 2010 | 04:56 PM
sutekidane's Avatar
OP's talking about the hangup button... if you hold it for a few seconds, the diagnostics prompt will tell you the HFL system is OK. the said trick was mentioned in the tsx easter egg thread many years ago.
Old May 30, 2010 | 08:55 PM
I kinda thought this might be a repost. Well at least for a secondi thought i had found something new.
Old Jul 22, 2010 | 10:40 PM
Mopos's Avatar
What if holding the button doesn't do anything? Probably means it is time to replace it? What about some of these battery disconnect or fuse pulling ideas?
IBankMouse
Jun 13, 2020 12:53 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
STL TL-S
Sep 23, 2015 08:52 PM
Markbby06
Sep 17, 2015 02:30 PM
