Help me diagnose my problem
So, this past week we got about a foot of snow. The day after, on my way home from work on the freeway, my car was shaking really bad. At the time I kind of figured that it had something to do with the snow/ice that was built up somewhere. Sure enough, the problem eventually resolved itself. In talking to the service guy at my dealership he explained that what probably happened was that ice has built up on the rims causing the wheels to become unbalanced. However, even now I still seem to notice that something is not quite right. First, it seems that the car just doesn't ride as smooth as it did before the snow storm. Second, it seems that my steering wheel is overly sensitive when going over bumps. Lastly, when pulling the wheel all the way over to one direction and then moving, the car almost seems like it slips. If any of these symptoms sound familiar to anyone, please let me know your thoughts. I just have that feeling where I am not sure I am imagining things, or if there is a real problem. I just took my car in today for an oil change and tire rotation, and kind of mentioned this, but the guy passed at off as a result of what I explained earlier (ice/snow build up on the rims causing imbalance), and they didn't mention anything after doing the tire rotation (although they weren't looking for a problem). Is there something wrong with my alignment/toe camber? Is it possible for wheel weights to fall off?
First of all, let me second the second post.
Secondly, try to get an experienced driver to test drive your car -- perhaps someone at an independent alignment shop or someone else in the local area that has had a TSX for more than a year.
Are there still slippery spots on the roads? If so, it could explain most of what you experience. Do you get the same experience with the VSA on and with the VSA off (in the same area, in the same conditions). When you go over bumps, are you on the throttle or off the throttle (it is best to be off the throttle). Do you need to take the bumps slower?
Check the tires for any blisters or bald spots. If you experience a periodic sound, or vibration, when the tire rolls along, you might consider having both your wheels, and your tires, checked for runout (roundness). The first checks the metal wheel. The second checks the tire mounted on the wheel.
But a 1/2 inch drive torque wrench (or at least a pull handle), a 6 inch extension, and a six point socket of the correct size (17 or 18mm?). Set all lug nuts to the proper torque (is it 90 lbs?). Then, wrap the tools in an old tower, surround with 3-4 #64 rubber bands and store in your spare wheel well for future use. Under the lug nuts, where they contact the wheel, and also on the treads, apply a little white grease (the grease used for garage doors also works well).
What year is your car and how many miles? How long have you had it?
Your description is too vague to be indicative of any specific problem. So, the best idea I can give you is to have someone experienced and knowledgeable (other than the dealer) have a look. Usually, when something doesn't feel right -- something isn't right. But, not always.
ok, so I think any issue I may have thought I had with the car not riding as smooth are gone. The only thing that I think still may be off is perhaps the camber of the front wheels. However, I think my alignment (in the sense that the car drives straight) is fine. Is it possible for the camber to be off, but the car does not drift to either side when taking your hand off the wheel?
Sure. See: http://www.familycar.com/alignment.htm
I imagine that even toe-in being off would not necessarily cause a drift. The only way to know if the alignment is off is to put the car on a good rig that can check all four wheels. We have independent suspension in the rear, so it can also be out of alignment -- easier than with a straight shaft.
For alignment, you might want to consider the dealer. Otherwise, stick with a shop that does nothing but alignments.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
