Help Improve Responsiveness
Old May 17, 2008 | 12:54 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Hey guys,
Looking for some input, I recently picked up a set of 18x8” aftermarket rims, though I love the way they look my TSX they do weigh a considerable amount. I was looking for suggestions on what I can do to my vehicle to make it feel like it did before I put the aftermarket wheels on, such as pulleys, throttle body spacer etc? I am looking to improve bottom end torque and overall responsiveness.
btw; I do know that picking up a set of heavy 18x8’s wasn’t the smartest thing to do but they’ll have to do for now, hopefully when I save up enough money I can sell these and look into a lighter more sportier styled rim, volk, work, eneki etc.
Its a 2005 Auto, engine mods consist of a Injen CAI.
Old May 17, 2008 | 01:03 PM
RA032025's Avatar
in the 24th and a half...
Originally Posted by GTSX-05
Hey guys,
The problem you face is simple...heavier rims and often heavier tires equal slower response. Best thing is to look into 17" lightweight rims...
Your solution to add power is simply gonna wear out the engine sooner and reduce you gas mileage.
X O
Look Pimping <------------------------------------------------------------------>Go Faster
Choose a point on the spectrum...X is now, O is before the rims.
Old May 17, 2008 | 01:05 PM
godfather2's Avatar
Time to Climb
first, post pics
second, get the suspension dialed in (the tsx shines in this aspect)
- rear sway bar
- shocks/springs or coilovers
third, pulleys (because it really frees up some power for us auto trannys)
Old May 17, 2008 | 01:11 PM
GTSX-05's Avatar
ASM 3G TL Type-S
I have posted pictures before but;
I am running tokcio hp blues, rs*r down springs, and a h&r rsb.
Old May 17, 2008 | 01:15 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Are pulleys worth getting with an automatic transmission care to explain? Will I feel a noticeable gain?
Originally Posted by godfather2
first, post pics
- rear sway bar
Old May 17, 2008 | 02:13 PM
godfather2's Avatar
Time to Climb
you'll be able to rev a bit more freely due to less parasitic loss
responsiveness will improve as well
pulleys and headers are simplest ways to achieve higher torque numbers
Old May 17, 2008 | 04:26 PM
jumpmanbsktbll's Avatar
2.4 L iVtec
ive got an 04 auto w/ comptech icebox (best of all the intake IMO - dont loose much compared to the other CAIs), throttle body spacer, p2r thermal intake gasket, hondata gasket...improved throttle response a good amt for those small mods
Old May 17, 2008 | 06:12 PM
lcrazyaznl's Avatar
CL9 ABP
look into hondata, and you might not be disappointed. doh 05 at
04 ecu =)
pulleys and headers will help enough. Other than that lightweight rims and tires.
Old May 18, 2008 | 10:50 AM
bluecarbonfiber's Avatar
WTF?
you can tighten the throttle cable that goes to your DBW system.. there is alot of slack in it.. that will help your response alittle while youre in the auto mode vs sport shift.
Old May 19, 2008 | 09:47 PM
cali4tsx's Avatar
I had the same problem before
I bought a set of havey 18s and I seroiusly lost some "take-off power".. but now I replaced them with much lighter wheels.
Once u get the $ I suggest u go same route as well
Old May 20, 2008 | 07:54 AM
DAYTA's Avatar
If you want better low-end grunt, I'd ditch the Injen and switch to a Comptech Icebox. It won't sound as mean as the Injen, but you'll definitely gain back some low-end power and response.
After that, I'd agree with godfather's recommendations and add a header + pulleys .
Old May 20, 2008 | 09:30 AM
ennzzo's Avatar
Comptech icebox.
Old May 20, 2008 | 09:47 AM
ThirdLane's Avatar
I could tell you now that with your new Heavy rims and tires, you are not going to regain the responsiveness you've lost. Whenever you raise the unsprung weight of a car, you lose a bit. Plus with larger diameter rims and tires, you effectively raise the final drive ratio losing the peppiness. I'd say go with lighter 17in rims and tires.
Old May 20, 2008 | 11:00 AM
DAYTA's Avatar
Well, assuming he put 235/40/18 tires on 18x8 wheels (which looks to be the case based on his pic), the difference in diameter between his current wheel/tire setup and stock would be negligible depending on tire selection.
Also, I don't know if I would correlate final drive ratio with peppiness. The OP is asking about low-end power loss, not top-end .
Old May 22, 2008 | 03:13 AM
csun2004's Avatar
time for lighter wheels @@
Old May 22, 2008 | 06:39 AM
Audioserf's Avatar
boost owns
This thread makes me glad I bought 19lb 18x8's.
However, I agree that pulleys would help. I'd say look into an RT Cat as well - for an 05 that will free up some power nicely.
Old May 22, 2008 | 08:34 AM
godfather2's Avatar
Time to Climb
^ what wheels are you running? my enkeis of the same size are 20lbs
Old May 23, 2008 | 01:47 PM
losothefatso's Avatar
Is the Comptech Icebox's loses compared to any Cold Air significantly different at the wheel? Because that was my second option.
TypeS860
Jan 10, 2026 11:11 AM
mlody
Dec 4, 2019 02:11 PM
rcs86
Aug 2, 2016 06:52 PM
DerrickW
Nov 15, 2015 05:52 PM
TL14
Sep 24, 2015 04:37 PM
