Has any tsx exprienced water seepage from underneath.
I checked the threads but could'nt find anything like this. 2 weeks back there was heavy flooding in oregon and my car had to go thru puddles of water. I noticed water (about 1/2 inch water) stagnating in the floormats on the driver read side and fully wet on the driver side one day after driving in the rains. now it is l at the dealer.They said they had isolated the problem and that they had to order some carpet kit to be replaced and the carpet kit has to come from overseas. what could be the problem of this water seepage. could this have any problems in the future,can somebody help?
thanks / nanda
thanks / nanda
Rep'n Taxbrain.com
Where you using your a/c or heature when you noticed the stagnant water on the floormats?
Other than that my guess would be that if you were going through some super high puddles that maybe some water got in
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Have camera, will travel
thanks / nanda
thanks / nanda
I wonder if cold then warmer weather can cause some kind of condensation under there. I'll double check to see if the carpet area is wet.
Let me help you!
Originally Posted by ck123
not sure, i dont drive the tsx in the rain
Anyway, is it just the carpet, or are other things wet as well? Maybe the window wasn't closed all the way?
I don't believe there's a drain anywhere in the wheel well. Although when I had the dead pedal off, I might have seen a hole or two...not sure if they would be accessible from the outside, but it might be a route that water would take...
GWEEDOspeedo
01-15-2016 10:39 PM
STL TL-S
09-23-2015 08:52 PM
