got subs (100% proof get rid of rattline noise)
i just got an alpine 10inch type r and with 360 watt rms enough to run the sub but i am getting noise from the trunk can i take the back seat lock out cause i never lock it anways
the rattle can be the license plate frame in the back. you can bolt it in on bottom or put something behind it so it could stop. Or if its not the license plate frame, then it could be something else
There are rubber flap vents in the back corner of the trunk area that lead to the outside that are part of the fresh air ventilation system and they will rattle back and forth causing a flapping noise.
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
