Goo....green or yellowish goo....sticky
hello all. it's a newwwwbie. ok first, i did a search and couldn't find the word "goo", "green or yellow goo", or "sticky goo" in the forum. so please don't get mad if this has been answered before us girls do want to follow the rules in here.
ok....here goes....drove my car all day and didn't notice this until i came home from work. on the passenger side floor mat (by the way, i bought the all weather rubber mats from acura), there was this liquid. it is NOT water but some other substance (thicker than water). i didn't notice it this morning and NO ONE was riding with me the whole day (no one has sat on the passenger's side the past week).
it cleaned up easily but i'm just worried it's a leak from somewhere. is there anything under the glove compartment that is a thick liquid substance? i have been running the ac since the weather was hot the past few days (could that be the problem?). what do you all think this is? i wish i took a pic now....but it would have probably made it look like it was water (and it's not). it's a thick yellowish/greenish goo. let's say it's a consistency of jello when it's almost hard.
from michelle aka tsexy_grl
wow after reading that i remembered the first time i vacumed my tl i found some yellow goo..ish? stuff in my carpet on the passenger side. It came out real easy i just didn't know what it was...what does it have to do with the cabin filters? type of lubricant they use?
Originally Posted by PACman
Check your cabin filter.
Do you have any liquid in your glove box?? The cabin filter is easy to get to and check. It's a dry filter but something may have been caught in it. The instructions for getting to the filter is in the owners manual.
BTW, welcome to AZ
BTW, welcome to AZ
BTW, welcome to AZ
BTW, welcome to AZ
so i'm so confused. i just don't want this to cause any damage. would it? has anyone else experienced something like this?
TSX MFG Date Sep 2006
Would you be able to take a picture of this 'goo', then upload it so we can see. Perhaps this would give up an idea.
I know, I know, after having said that, I probably misread something she said... it always happens to me, like for example, I get annoyed at seeing so many misspellings (not mistyped - you can tell if the author keeps 'mistyping' over and over again) and calls out on the author, and then someone advertently points out my own foibles.
Originally Posted by cestmoi
Sorry to be harsh on you, but just because you know how to read doesn't mean you've yet mastered the art of understanding what you've just read. I suggest you re-read one of her post where it mentioned that she WISHED SHE HAD TAKEN A PICUTURE of the goo... and since she's already cleaned it up, there's nothing to take a picture of <<--- implied and should be understood from reading that...
:smitler:
日本国内市場の売春婦
Well, inside the glove compartment.. all I see are a bunch of wires and the filter.. the filter doesn't look like theres any liquid associated with it.... it's just a plastic frame holding the paper filter.
日本国内市場の売春婦
I looked because I had to take out the cabin air filter to check how dirty it was and if it needed replacement or not. It's a fairly easy task to open up the glove compartment. Check pg 280 of your manual.. maybe if you look in there you can find your problem.
I have seen this before...
in my case it was water from the evaporator ( the drain tube was loose ) when the water reacted with the all season mats it turned a yellowish green color. we cleaned it up the same day, in your case it may have been there a few days and thickened up some.
i dunno
if you dont believe me go put some water on your all season mats and see what happenes.....
i dunno
i dunno
i dunno
the drain tube is at the bottom and behind the evap case which is under the glove box it is a little hard to see turn the a/c on an see if and were it leaks if you cant find the leak take it to service
i dunno
i dunno
Perhaps there's something on the surface of the mats that's meant to be rinsed off before use??
no it is a type of coating on new mats that reacts with water. its harmless...... i hope
as far as finding it in your gas tank ....................... uhhhhhuhhhh
Amoeba
2G CL Transmission Recall Q & A
10-08-2003 04:18 PM
Amoeba
10-02-2003 10:08 PM
