Fuse Box Question
Fuse Box Question
This may be an already sated question but I'm looking to have my radar detector connected into my fuse box...actually it's already connected into my fuse box but my real question is where can i attach it too in which it will only turn on when I turn on the car. Cause right now I have it set to the cigarette adapter fuse and apparently it's constantly feeding it power when the car is not on which is not what I want.
Thanks in advance
Thanks in advance
B A N N E D
Thanks in advance
Thanks in advance
and use the fuse that says acc (accessory)
easiest way to do it without having to spice or jury rig anything.
Originally Posted by 925tsx
Get this........... http://www.partsexpress.com/pe/pshow...TOKEN=31389396
Originally Posted by Tsx536
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
This is from an 04 TSX:
![](http://img.photobucket.com/albums/v483/Kenray536/FuxBoxWiring.jpg)
B A N N E D
TSX536, Thanks for the picture however I dont have those black fuses in my 06 Fuse Box. Not really sure what those are anyway.
dude those black things are the part that i posted.
Ok so I got that part and i tried setting it up but for some reason it's not working Can't figure it out for the life of me. I have it connected properly I put a 10Amp fuse in it, and it's properly configured. My only concern is that the blue part at the end of the device puzzles me a bit. I connected the the lead wire into the blue part of the fuse attachment and it just seems like it's not feeding it power. What am i doing wrong?
B A N N E D
did you ground it?
did you crimp the blue part once you put the lead into it?
Let me help you!
Originally Posted by msmching
sry.. but what's that radar detector for?!?!
Anyway, it picks up stray radar signals (ie: bounced off the car in front of you that's been "shot" by a cop...thus alerting you that there's a cop ahead that's checking speeds). Sometimes it might be too late (and is simply a "get ready to be pulled over" signal), and sometimes it can get false positives.
Ok i figured out what was wrong.
The add-a-fuse circuit holder i purchased actually had in it two slots for fuses. Now me going into my senior year for electrical and computer engineering quickly negated the notion that it needs to fuses since it acts in series, and only put it one fuse. Which is the sole reason for why this simple 2 minute task turned into an arguous 30 minutes + 8 beers extravaganza.
Originally Posted by SoCaliTrojan
it's for people who can't drive sensibly and like to speed in places where cops often set up speed traps ;-P
is simple a 'get ready to be pulled over" signal
