Fog light question for 06 tsx
Old 04-24-2006, 08:25 AM
dwest1023's Avatar
Does anyone know where he fog light relay is on the o6 tsx? I am going to wire the fog lights so I can have them come on with the parking lights. This is an easy mod if I can find the relay. All it will involve is cutting the a wire from the relay and wiring it to the hot parking light wire or relay. I have done this on my mazda.
Old 04-24-2006, 09:17 AM
STL
STL's Avatar
http://www.acura-tsx.com/forums/showthread.php?t=28783
Old 04-24-2006, 10:06 AM
dwest1023's Avatar
Not sure how that helps, but the mod is easy. Just need to find the fog light relay. I have seen the wiring diagram for 04-05 but not 06.
Old 04-24-2006, 10:13 AM
STL
STL's Avatar
I referenced that thread because according to moda_way, what you are wanting to do has been looked into and found not to be easy. At the time, I didn't realize you started both threads.
Old 04-24-2006, 10:21 AM
dwest1023's Avatar
No, problem. It IS easy if I can locate the wire the makes the fog light rely hot. Everything will work the same including the dash light. I just did this on my 2006 MX 5 convertible. There is nothing to it. On the 04 diagram I see the wire I need to mod, but I am not sure if it is the same for 06. If I can find the relay I can test for it. The swith is doing nothing more then swtiching ground. I cannot see why this is said to be hard. Its just basic electronics.
Old 04-26-2006, 07:36 PM
poltergeist's Avatar
Sorry but it's not that easy. It's a totally different circuit design than what your Mazda may have used (speaking of the '04-'05.....it's possible, but not likely, that it has changed for '06).
The foglight relay is hot at all times (on the '04-05 it's under the fusebox on the L/F shocktower). It is switched to ground through the multiplex with a signal originating inside the headlight/foglight switch. Really the only way (besides using an aftermarket separate foglight switch to ground the relay) is to disassemble the headlight/foglight switch and try and isolate the circuit internally inside the switch.
It's anything but "basic electronics."
Old 04-26-2006, 08:21 PM
Slashdotted's Avatar
Another option to look at is swapping out the light switch with one from a european market Accord, maybe their light switches are wired differently. For German cars, this is a popular & easy mod. It allows you to turn on the fog lights with the parking lights, without needing to have the low beams on. Good luck!
theinsvnity
09-10-2015 10:22 PM
ellisd03tls
09-08-2015 04:17 PM
cruisingnycfl
09-02-2015 12:11 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Fog light question for 06 tsx
