Fog light question for 06 tsx
Does anyone know where he fog light relay is on the o6 tsx? I am going to wire the fog lights so I can have them come on with the parking lights. This is an easy mod if I can find the relay. All it will involve is cutting the a wire from the relay and wiring it to the hot parking light wire or relay. I have done this on my mazda.
Not sure how that helps, but the mod is easy. Just need to find the fog light relay. I have seen the wiring diagram for 04-05 but not 06. |
Originally Posted by STL
I referenced that thread because according to moda_way, what you are wanting to do has been looked into and found not to be easy. At the time, I didn't realize you started both threads.
No, problem. It IS easy if I can locate the wire the makes the fog light rely hot. Everything will work the same including the dash light. I just did this on my 2006 MX 5 convertible. There is nothing to it. On the 04 diagram I see the wire I need to mod, but I am not sure if it is the same for 06. If I can find the relay I can test for it. The swith is doing nothing more then swtiching ground. I cannot see why this is said to be hard. Its just basic electronics.
The foglight relay is hot at all times (on the '04-05 it's under the fusebox on the L/F shocktower). It is switched to ground through the multiplex with a signal originating inside the headlight/foglight switch. Really the only way (besides using an aftermarket separate foglight switch to ground the relay) is to disassemble the headlight/foglight switch and try and isolate the circuit internally inside the switch. It's anything but "basic electronics." |
