Extended warranty questions.
Hello,
I am contemplating the idea of whether or not to get an extended warranty for my TSX. If I do so, and I get the Acura extended warranty till 100k, will that cover my leather seat covers? I know that I will normal wear and tear on them, but after seeing some recent threads about them actually shredding from entering/exiting habits, I am concerned that I might have some problems down the road. Anyway's, I was just curious if the extended warranty would cover this. Also, what would front seat covers cost for an 07 TSX - any ideas?
Thanks much!
Jeff
Thanks much!
Jeff
ENGINE
- Cylinder Block
- Crankshaft
- Main Caps
- Main Bearings
- Pistons and Pins
- Piston Rings
- Connecting Rods and Caps
- Rod Bearings
- Cam Shaft(s)
- Cam Bearings
- Timing/Balance Shaft Belts (for failure only)
- Timing Gears
- Timing Belt Tensioners and Bearings
- Timing Belt Cover
- Water Pump and Pulley
- Oil Pump Oil Pan
- Cylinder Head(s)
- Valve Covers
- Rocker Arms and Adjusting Screws
- Rocker Shafts
- Rocker Bushings
- Intake and Exhaust Valves
- Valve Springs
- Valve Retainers
- Valve Guides and Seals
- Pushrods
- Lifters
- Followers
- Engine Mounts
- Intake Manifold
- Exhaust Manifolds
- Oil Pressure Switch
- Serpentine Belt Tensioner
- Seals/Gaskets for the above stated parts
AIR CONDITIONING/ HEATING
- Compressor
- Compressor Clutch & Pulley
- Field Coil
- Condenser
- Condenser Fan
- Evaporator Core
- Receiver Drier
- Accumulator
- Metal Refrigerant Lines
- 0-Ring Seals
- Idler Pulley and Bearing
- Temperature Control Unit
- Heater Control Cables
- NC Blower Motor
- Blower Motor Resistor Heater Core
FUEL DELIVERY
- Carburetor
- Throttle Body
- Throttle Cable
- Fuel Delivery Pump Relay
- Fuel Injectors
- Fuel Distributor
- Fuel-Injection Pump
- Anti-Detonation Sensors
- Computerized Mixture Control Unit and Sensors
- Fuel Tank and Sending Unit
- Metal Fuel Delivery Lines
ABS BRAKES
- ABS Electronic Control Unit
- ABS Pump
SRS SYSTEM
- SRS Control Unit
- SRS Cable Reel ELECTRICAL
- Starter
- Alternator
- Voltage Regulator
- Insight Nickel-Metal Hydride Battery
- Front or Rear Windshield Wiper Motor
- Front or Rear Windshield Wiper Washer Unit
- Power Window Motor and Regulator
- Starter Motor
- Starter Solenoid
- Mileage Computer
- Wiring Harnesses
- Manually Operated Switches
- Electrically Operated Switches
- Distributor
- Igniter
- Ignition Coil
- Electronic Combination Entry System
- Computerized Timing
- Control Unit and Sensors
- Sunroof Motor
- Power Seat Motor(s)
- Antenna Motor and Mast
- Power Door
- Lock Actuators
- Rear Window Defogger
- Factory-Installed Anti-Theft System
- Horns
- Digital or Analog Instrument Cluster
- Electrical Motors and Control Units
MANUAL COMPONENTS
- Window Regulators
- Window Run Channels
- Seat Tracks
- Door Latch Assembly
- Lock Cylinders
BRAKES
- ABS Switch
- ABS Wheel Sensors
- Master Cylinder
- Vacuum Assist Booster
- Check Valve
- Disc Brake Calipers
- Wheel Cylinders
- Compensating Valve
- Hydraulic Brake Hard
- Lines and Fittings
- Parking Brake
- Lever Assembly
- Parking Brake
- Linkage and Cables
- Self Adjusters
- Springs
- ABS Modulator
- Brake Accumulator
- Dust Shields
- Backing Plates
COOLING SYSTEM
- Radiator
- Thermostat and Housing
- Coolant Temperature Switch
- Radiator Cooling Fan Motor
- Cooling Fan Blade
- Cooling Fan Shroud
- Cooling Fan Switch
- Cooling Fan Relay
- Cooling Fan Timer
- Cooling Fan Clutch
- Coolant Recovery Tank
- Seals/Gaskets for above stated parts AUTOMATIC TRANSMISSION
- Transmission Control Module
- Lockup Control
- Solenoid
- Shift Control Solenoid
- Shift Interlock System
- Shift Cable
- Throttle Pressure Control Cables
- Vacuum Modulator
- Transmission Case and all internally lubricated parts
- Torque Converter
- Flexplate
- Transmission Mount(s)
- Oil Pan
MANUAL TRANSMISSION
- Shift Cables
- Flywheel
- Clutch Master and Slave Cylinders
- Pilot Bearing
SUSPENSION SYSTEM
(FRONT AND REAR)
- Upper and Lower Control Arms
- Control Arm Shafts and Bushings
- Upper and Lower Ball Joints
- Stabilizer Bar, Links and Bushings
- Coil Springs
- Spindles
- Wheel Bearings
- MacPherson Strut Assembly
- Shock Absorbers
STEERING
- Steering Column
- Steering Gear Box
- Rack & Pinion Housing and all internally lubricated parts
- Power Steering Pump & Pulley
- Inner and Outer Tie-Rod Ends
- Tie-Rod Adjusting Sleeves
DRIVE AXLE SYSTEM
(FRONT OR REAR)
- Drive Lines
- Constant Velocity Joints and Boots
- Hub Bearings
- Axle Bearings
ACCESSORIES
- Genuine Honda Electronic/Audio Accessories
- Factory-Installed Navigational and Security Systems
REAR DIFFERENTIAL
- Differential Housing and all internally lubricated parts
- Axle Shafts
- Axle Bearings
WHAT IS NOT COVERED
Exclusions include but are not limited to body parts, tires, maintenance items, glass, upholstery, trim, carpeting and ornamentation. While every effort has been made to provide a complete listing of covered and non-covered parts, this information is intended to provide an overview of coverages. Actual contract coverages, limitations and exclusions may vary. See the sample contract for full details. © 2005 American Honda Finance Corporation
From www.curryacuracare.com ----> coverage
- Cylinder Block
- Crankshaft
- Main Caps
- Main Bearings
- Pistons and Pins
- Piston Rings
- Rod Bearings
- Cam Shaft(s)
- Cam Bearings
- Timing Gears
- Timing Belt Cover
- Oil Pump Oil Pan
- Cylinder Head(s)
- Valve Covers
- Rocker Shafts
- Rocker Bushings
- Valve Springs
- Valve Retainers
- Pushrods
- Lifters
- Followers
- Engine Mounts
- Intake Manifold
- Exhaust Manifolds
- Compressor
- Field Coil
- Condenser
- Condenser Fan
- Evaporator Core
- Receiver Drier
- Accumulator
- 0-Ring Seals
- NC Blower Motor
FUEL DELIVERY
- Carburetor
- Throttle Body
- Throttle Cable
- Fuel Injectors
- Fuel Distributor
ABS BRAKES
- ABS Pump
SRS SYSTEM
- SRS Control Unit
- Starter
- Alternator
- Voltage Regulator
- Starter Motor
- Starter Solenoid
- Mileage Computer
- Wiring Harnesses
- Distributor
- Igniter
- Ignition Coil
- Sunroof Motor
- Power Door
- Lock Actuators
- Horns
MANUAL COMPONENTS
- Window Regulators
- Seat Tracks
- Lock Cylinders
BRAKES
- ABS Switch
- ABS Wheel Sensors
- Master Cylinder
- Check Valve
- Wheel Cylinders
- Parking Brake
- Lever Assembly
- Parking Brake
- Self Adjusters
- Springs
- ABS Modulator
- Brake Accumulator
- Dust Shields
- Backing Plates
COOLING SYSTEM
- Radiator
- Cooling Fan Blade
- Cooling Fan Relay
- Cooling Fan Timer
- Lockup Control
- Solenoid
- Shift Cable
- Vacuum Modulator
- Torque Converter
- Flexplate
- Oil Pan
MANUAL TRANSMISSION
- Shift Cables
- Flywheel
- Pilot Bearing
SUSPENSION SYSTEM
(FRONT AND REAR)
- Coil Springs
- Spindles
- Wheel Bearings
- Shock Absorbers
STEERING
- Steering Column
- Steering Gear Box
DRIVE AXLE SYSTEM
(FRONT OR REAR)
- Drive Lines
- Hub Bearings
- Axle Bearings
ACCESSORIES
REAR DIFFERENTIAL
- Axle Shafts
- Axle Bearings
WHAT IS NOT COVERED
acuraautomotiveparts.com shows the cover set for the seat back to retail at $576.25 ($461.00 their price) while the cover for the seat cushion retails for $618.58-$615.48 ($494.86-$522.78 their price) depending on color.
emailnatec
29
09-28-2018 04:27 PM
