Equipping garage for new TSX
'06 TSX 6MT
Hi everybody!
I've been lurking for about a month, and i decided it's time to post up. Any-who, my '06 TSX (Arctic Blue 6MT) is now at 1000 miles, and i'm getting ready to do my mid-break-in oil change. I already put together a pretty good garage to keep my '93 infiniti G20 running through 175k miles, but i want to know if there's any special tools i should get for the TSX. Specifically- will the standard 2 1/4 ton Craftsman floor jack cut it for lifting the front and rear to get the car up on stands, and has anyone had a problem with ramps not fitting under the front lip on a stock TSX? Also, does anyone know the part number for the Honda oil filter cap wrench that fits our filter?
TIA
-Ari
TIA
-Ari
'06 TSX 6MT
Originally Posted by virus7
for all your oil changing parts:
http://www.handa-accessories.com/tsx.html
Originally Posted by Lone Starr
Hi everybody!
TIA
-Ari
TIA
-Ari
i want to ride my bicycle
I was hoping to swing by a local Honda dealer to pick up the tool, but that site doesn't have the part numbers on it
oh and if you are planning on changing your oil before the manual, i'd say don't.
'06 TSX 6MT
This is a hotly contested issue in many many threads here, but here's the gist-
during the break-in period (anywhere from 1k-10k miles depending on who you ask), little tiny pieces of metal are being shaved off all the moving parts in the engine (not as many as there used to be thanks to modern machining techniques). Acura ships our engines with an additive put into the oil to reduce wear caused by the metal particles floating around in there, but they're still not so great for the engine. Therefore, at 1000-1200 miles, some people do the first oil change. Also at this point some people switch to synthetic... I was planning on going this route until i learned about the additive- so i'm going to replace the oil with a similarly-formulated dino oil for the oil changes at 1200 and 5000, and go to synthetic after that, following the maintenance minder thereafter.
....Therefore, at 1000-1200 miles, some people do the first oil change. Also at this point some people switch to synthetic... I was planning on going this route until i learned about the additive- so i'm going to replace the oil with a similarly-formulated dino oil for the oil changes at 1200 and 5000, and go to synthetic after that, following the maintenance minder thereafter.
so basically you're just going to ignore factory recommendation issued by the ENGINEERS THAT DESIGN & BUILD the car
and do what you "think" is good for your car
...more power to you then.
I purchased the "special" tool for the oil filters, but would say don't bother with it. All it is a special cap that fits over the end of the filter that you then attach a socket wrench to. The problem is that often times the tool doesn't fit perfectly over the filter and has some play in it. When this happens the tool just slips on the filter when you try to turn it. I tried using that tool once, but then after that have just stuck with using a standard band type oil filter wrench. There isn't much room, but I'm still able to manuever the wrench around enough to be able to grip the filter with it.
Just dial 1911
1 Post
Their was a thread where our resident oil expert, Michael Wan, suggested around 1000 miles to change the dyno oil...
Just dial 1911
1 Post
'06 TSX 6MT
In the same vein that Lone Starr said...
The factory recommendation is likely a compromise between many different Honda employees including but not limited to engineers, marketers, and accountants. Of course, not everyone has equal say. Ultimately, a manager listened (hopefully!) to the advice of his subordinates and came up with the official oil change schedule.
It's indeed possible that all parties at Honda agreed upon the official recommended oil change schedule. However, I would bet that the engineers tend to want shorter oil change intervals than recommended and marketers/accountants want longer.
the ENGINEERS THAT DESIGN & BUILD the car only care that X percent of new TSXs last Y years, and X/Z percent last 2Y years. their recommendations about maintenance are based purely on a cost/risk analysis, not keeping a car running in peak condition for as long as humanly possible
Originally Posted by jihan3
I doubt that this is the case.
Can you guys back any of those "assertions" up ? with like a reference link ?
Doesn't have to be Honda - any Jpn maker will do.
:urbanlegend:
I'm just going on what I've observed of the (business) world in general. Managers make the decisions, and their decisions based on advice from their subordinates. Few things on this earth are cut and dry, so compromises are commonplace.
I have no reference to cite. Do you have a reference for your assertion?
Owner manual, ownerlink, acura.com
I wasn't aware I made any assertion of my own but my statement about factory recommedation was based on what is published :
Your assertion is that the published oil change interval is what the engine designers recommend.
Let me know when you find a reference.
https://acurazine.com/forums/car-talk-5/car-show-34166/#post387872
see post #8
Yes, I equate "factory recommendation" to "engineer/designer recommendation" - maybe I'm alone in this interpretation, maybe not
mlody
12-04-2019 02:11 PM
