Engine Idle Speed
Old Oct 21, 2005 | 12:41 AM
Precisi0n's Avatar
5th Gear
Engine Idle Speed
I searched through 10 pages of threads and couldnt really find an answer to my wifes question... She noticed when she pushes the clutch in while driving or stopped... The idle speed will not dip below 1000rpm when driving or 700rpm when completely stopped... From what I can gather, it is some sort of anti-stall program with the drive-by-wire, but I'm still wondering if that is suppose to happen... Any help would be greatly appreciated...
Old Oct 21, 2005 | 01:11 AM
JTso's Avatar
Well, the idle speed should be around 750 rpm during idle for the MT. Not sure about your question about not going lower than 1000 during driving.
Old Oct 21, 2005 | 01:52 AM
HoRRo's Avatar
iVTEC no koe
mine is 750, clutch in and out.
Old Oct 21, 2005 | 01:56 AM
Powered by Honda's Avatar
defective car?
Old Oct 21, 2005 | 01:58 AM
Precisi0n's Avatar
5th Gear
I figure 700-750rpm is good for stopped idle speed but i still dont understand why it wont drop below 1000rpm when the car is moving thanks for the replys...
Old Oct 21, 2005 | 02:30 AM
HoRRo's Avatar
iVTEC no koe
err.... moving, hmmm... I will have to check that tmrw to say 100%, idle clutch in and out is what I meant, I'll post again after confirming rpm while moving
Old Oct 21, 2005 | 08:47 AM
JTso's Avatar
There is a flywheel that attaches to the engine to keep the engine rpm up due to momentum. I also believe the system is designed to keep the rpm up in between shifts to further reduce emission by burning off excess fuel.
Btw, I still don't quite understand the question...
Old Oct 21, 2005 | 10:29 AM
afici0nad0's Avatar
i think 1K rpm when clutch-in while in movement is normal, and i think 750 rpm is normal for idle, regardless of whether the clutch is engaged or not...
Old Oct 21, 2005 | 11:03 AM
S14 n Tsx's Avatar
mmmmmm....
yup, 750 RPM is normal for idel.
When you start your car in the morning= 1500 RPM
2mins warm up=1000 RPM
GOOD TO GO!!!~
Normal idel=750 RPM
Old Oct 21, 2005 | 02:27 PM
afici0nad0's Avatar
GOOD TO GO!!!~
Normal idel=750 RPM
right on...
Old Oct 21, 2005 | 02:38 PM
tsxei's Avatar
TSX now. NSX some day.
hmmm...I always wondered why the rmp shoots up momentarily in between shifts when up-shifting.
Old Oct 21, 2005 | 03:32 PM
kmonster's Avatar
yeah I have heard that normal idle RPM's are 700-750...my old RSX Type S was also the same....anything higher is just the engine trying to get itself to a warmer temp.
Old Oct 21, 2005 | 04:11 PM
ldubuc's Avatar
It is normal. It is a control emissions issue. In order to produce less emissions, you have to control the rate of deceleration of the engine. This is what the engine control electronic does. Do the test yourself, run at steady speed, release the gas, then press the clutch, you will see that the rpm drop to 1000 then to 750.
ld
Old Oct 22, 2005 | 03:32 AM
HoRRo's Avatar
iVTEC no koe
so yeah, finally tested it. Stopped = 750, moving = 900.
Old Nov 29, 2005 | 06:05 PM
rtlltj's Avatar
I have an AT but when slowing down from a stop I notice the rpm will shoot up to like 1000 and back down and forth.
Old Nov 29, 2005 | 06:14 PM
feliz's Avatar
Sounds like the motors toast!!
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
Mike Bertram
Sep 10, 2015 09:27 AM
Papa Roe
Sep 1, 2015 09:41 PM
