Downshifting
Old Mar 10, 2004 | 08:51 AM
ctbrock's Avatar
Downshifting
Hello,
I have a TSX Automatic, with sport shift. While around town, I set it in automatic mode (no sport shift) and have noticed that if I am coasting - with speed slightly slowing down - that my TSX will automatically shift down, with a noticable 'jerk' in speed (higher rpm with a higher gear), slowing my car down more....kinda strange......and I need to know if this is 'normal' or not. Is this something to be concerned about? Its more annoying than anything...I would rather it not downshift until I push the pedal down for more speed.....not when the car is slowing down to a stop!
Any thoughts, or similar experiences?
Thanks!
Tod
Old Mar 10, 2004 | 08:54 AM
Dan Martin's Avatar
Photography Nerd
That's mostly common. If it is a really jerky downshift you might have a problem but it sounds like it's functioning as designed.
Old Mar 10, 2004 | 06:47 PM
kiteboy's Avatar
I use SS 95% of the time. The auto-downshift, both in "M" and "D" occurs at such slow speeds (for the lower gear), you should not notice any engine braking. The speeds are:
5>4: 52 km/h
4>3: 32 km/h
3>1: 10 km/h
(sorry you'll have do the mph conversion if you want). You will want to verify that these are speeds your car shifts at.
The only time I notice engine braking is if I manually downshift more than 20 km/h over the above speeds. The tranny _has_ to shift down automatically as your speed slows, otherwise, the engine will lug and eventually stall because the gearing is too high for the slow speeds.
Mike Pilipenko
Mar 26, 2024 09:21 PM
kixo
Sep 5, 2015 08:54 PM
mrlemonjello
Sep 1, 2015 08:52 PM
Crazy Bimmer
May 2, 2010 06:34 PM
Universe93B
Mar 28, 2001 08:43 PM
