Down-shift question on 06' TSX AT....
Old Apr 6, 2007 | 02:49 PM
ChicagoTony's Avatar
One of the few complaints on the TSX:
When in full automatic mode and going, say, about 45-55mph in top gear and I pretty much slam the gas pedal, I consistently notice the downshifts to 4th, then 3rd, and finally 2nd - which is what I expected the tranny to downshift to initially.
With the drive-by-wire setup, I would expect a 'cleaner', more 'instant' downshift into a lower gear depending on the force I place on the accelerator. This is a non-issue when is SS mode, but obviously it takes at least a couple pulls to get to the lower gears.
Is this a mechanical/warranty issue or pretty much the norm?
Old Apr 6, 2007 | 08:41 PM
mikeucla's Avatar
I would think it's the norm, but I'm not sure. I've got a manual.
Wow, you can be in 2nd gear at 60mph+? that sounds crazy! i mean, say you're at 45 in 5th gear, you slam the accelerator, it takes you to 4th gear, by 50 you're in 3rd gear, 55 and 2nd gear!
i think they made the manual tranny with the gearing tall enough so you could just hit, and maybe go slightly over 60mph in 2nd (for the 0-60 test), but the manual has 6 gears. i didn't realize the gearing ratios would be that similar in the 5 speed.
i'd probably stick with SS if the delayed downshift bothers you. my $0.02.
Old Apr 6, 2007 | 08:55 PM
gtg710w's Avatar
06 GBM AT TSX + 35% TINT
probabaly for durability reasons, skipping gears is not good for any tranny, AT and MT
Old Apr 6, 2007 | 08:58 PM
Reach's Avatar
Nothing wrong with your car, that's normal behavior. ATs always take longer to cycle down low and find you some power.
Old Apr 6, 2007 | 09:37 PM
Still Water's Avatar
Punch the pedal twice. First to drop one gear and then the next. Remember you are training/talking to your car's brain. It's very smart but it's not a mind reader. This is a technique that can be learned to help address the famous hesitation problem (pre-reflash). If done correctly you can smoothly go from pulling torque into vtec. Keep in mind you're driving a high rev 4 banger not a 6+ torque monster.
Old Apr 7, 2007 | 05:54 AM
Tex929rr's Avatar
Why would it matter in a manual transmission?
divac
Aug 29, 2018 10:13 AM
Heyzuez20
Oct 14, 2015 07:18 AM
atsx1313
Sep 22, 2015 09:04 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
