Doing Rear Brakes, Quick Question...
I just finished installing new rear pads, and when I did the 2nd set I realized that the back of the pad has a little bump/nipple/tab/whatever you wanna call it that seems to want to fall into one of the channels on the caliper piston.
My question is...
I didn't pay any attention if this bump/tab was aligned with one of the channels on the piston with the first side I did (I made sure things lined up the 2nd time around). Will the piston rotate and seat automatically, or should I take it apart and check it?
My question is...
Dude, their is a little tool that is a cube with different nubs on each face that is designed to be installed on a 3/8 socket wrench and used to roate the piston. Got one for $10 at Sears...called a "Disc Brake Piston Tool". Example from Amazon on below link:
http://www.amazon.com/Lisle-28600-Di.../dp/B0002SQUFY
BUY ONE!
BUY ONE!
