DIY VSA/Moonroof/Heater/ Gear shift lights
Old Dec 18, 2011 | 03:42 AM
  #41
calisoulsurfer's Avatar
Details...
So, trust me guys... you're not the only ones. I've got an 04 with 161K. I've replaced the VSA, Sunroof, both seat heater bulbs and then the third brake light bulb. Now I've got to replace the hazard and the gear selector bulb.
I just buy the OEM bulbs, but than again I am a parts advisor for a Kia dealership so I just pay cost plus ten on the Acura stuff. Even before that, I had no problem paying the $4 for a bulb than go through the effort the OP did.
Its still interesting how all these bulbs are going out for all of us. I had a 96 Integra that never had this problem at a 165K, and an 84 Accord with 287K that didn't either. Oh well...
Old Dec 18, 2011 | 03:59 AM
  #42
Originally Posted by lcrazyaznl
Center console light
I replaced the bulb and couldnt get the #74H to fit its a bit too big. Used electrical tape to get it held in place.
Now its a screw style so i only put a little layer of electrical tape on so i still was able screw it back in. This is a bright led, I tried it instead of an amber, since I always felt my gearshift light was too warm...
OK, I'm a little confused. Once you pull everything out of the way, how do I get the light bulb out to change it? I can see a black plug fitting in the left side, but I can't get it to come out. How do I go about getting it out? You got a video or pictures? I don't want to pay a dealer an hour's labor.
Old Jan 24, 2012 | 10:35 PM
  #43
MaverikDS's Avatar
I realize this is an old post and thank you for the time you put into it. I just had my drivers side seat warmer main light go out. I was wondering if you could show a picture of where exactly the first clip is behind the parking break to remove the center console. Also, I'm assuming it is but want to be sure, are the clips located in the same place for the manual and automatic? When you undo the first clip, are you doing it with the flathead vertical or horizontal? Thanks for any extra help you can give me.
http://www.youtube.com/watch?v=b0M0VMWLIFk
posted the video on how remove the center console
vsa/moonroof button
hazard light button
and center cubby
enjoy sorry if it stinks it just a quick vid
Old Jan 24, 2012 | 11:35 PM
  #44
I'm not the OP, but I changed my stuff out by reading this thread. I didn't have a clip, or I did and I didn't have to do anything special. I just started out by pulling up on the parking brake and then pulling up on the back of the console piece. I never needed a single tool until I had to turn the light bulb screw. You should be able to do it just like I did. Does that help any?
Old Feb 19, 2012 | 02:44 AM
  #45
Ck98vteC's Avatar
The good people at Lindsay Acura quoted me $6-8 a bulb so I got the Radio Shack bulbs and they are working out great I paid $4 for 4 bulbs just use tweezers when removing the bulb plastic covers. I found out the easiest way to remove them without tearing the delicate bulb covers is to just smash the old bulb with the butt of your screwdriver and slip the cover onto the replacement bulb.
Old Mar 6, 2012 | 01:12 PM
  #46
ahbaklikeu's Avatar
8th Gear
nice. im gonna check all the lights tonight! ;]
Old Jul 2, 2012 | 10:31 PM
  #47
Davu's Avatar
i just found these, and thought they would fit
http://www.dealextreme.com/p/0-91w-c...k-5-pack-47980
im ordering them today, and i'll see if they fit/work
Old Jul 19, 2012 | 06:41 PM
  #48
lcrazyaznl's Avatar
CL9 ABP
Sorry guys I haven't been around the thread and updated it. If you have any questions pm me and i will answer them.
Old Jul 27, 2012 | 03:59 PM
  #49
Davu's Avatar
just updating on the lights that i bought, they work great, they are the exact same size.
only had to switch the blue condom thing, and everything just went in place.
2$ for 5 pre-made is so much better than 5$ for 2 bulbs only
Old Aug 27, 2012 | 08:55 AM
  #50
hamman_25's Avatar
6th Gear
Nice write-up, I need to do this soon.
Old Jan 16, 2013 | 06:43 PM
  #51
TikkiTakki's Avatar
2+year update, these little Radioshack lights are still going strong!
Old Jan 17, 2013 | 12:05 AM
  #52
9177741977's Avatar
07-27-2012 4:59 PMDavu just updating on the lights that i bought, they work great, they are the exact same size.
Where can you get it ? and what is the bulb size ? i cant find it
Old Jan 17, 2013 | 07:13 AM
  #53
9177741977's Avatar
Where can you get it ? and what is the bulb size ? i cant find it ---what is that blue condom use for i brake that shit i thought it is a blue bulb WTF
Old Jan 18, 2013 | 02:05 AM
  #54
Davu's Avatar
i had it link in a comment right before it, here's the link again
http://dx.com/p/0-91w-car-instrument...k-5-pack-47980
the blue cover thing is only to make your lights appear white instead of yellowish
Old Jan 18, 2013 | 07:06 AM
  #55
9177741977's Avatar
Where can i buy the blue comdon. i break it OMG
it is Power: DC 14V/0.91W? not hot?
Dose this fit ? 0.56W Indicator Yellow Light Bulbs for Car Audio System (5-Pack)
http://dx.com/p/0-56w-indicator-yell...=47980&u=47983
Old Jan 19, 2013 | 03:01 PM
  #56
Davu's Avatar
no idea where you can buy the blue rubber, i don't think there would be much difference without the rubber since its such a small light.
the .91w isnt hot at all, and yes the .56w should fit. but why not buy the premade one?
Old Feb 26, 2013 | 07:46 AM
  #57
redpoint's Avatar
I wouldn't mess with the rubber caps, OEM bulbs, or buy the Radio Shack bulbs.
Get the NEO3 LEDs from Superbrightleds.com and never replace them again. You have to file the plastic down to get the bulb to fit into some of the sockets.
Old Mar 7, 2013 | 04:53 PM
  #58
gogozy's Avatar
if my calculation is right, the OE bulb 14v with 200mA is 2.8W, with 400mA each bulb is drawing 5.6W. the .91w only drawing 65mA. correct?
Old Mar 8, 2013 | 02:14 AM
  #59
redpoint's Avatar
The math is correct, but I don't know where you are getting the 400mA bulb. That would be quite bright for an instrument light.
The NEO3 LED bulb in my previous post draws 20mA or 0.28 Watts at 14 Volts.
Old Mar 8, 2013 | 05:17 AM
  #60
I<3JDM:Acura's Avatar
Random, but what's that RonJon logo button next to the VSA?
Old Mar 8, 2013 | 09:41 AM
  #61
gogozy's Avatar
oops, i re-read the thread, and i quote the wrong #.
the original honda bulb is 14v 40mA, Radioshack is 12V 60mA. so the OE consume 0.56W, while Radioshack rated at 0.72W, and placing Radioshack bulb in the TSX at 14V will actually consume ~51mA. .9W is too much... there is another one probably match our application better at .56W HERE notice the colour.. what does this mean?
- Color: Green
- Light color: Yellow
Old Mar 8, 2013 | 09:57 AM
  #62
gogozy's Avatar
found some 0.1-0.15W LED. Not sure if they would fit TSX. the LED colour maybe bluish without the cover?
0.15W, 1200~1400mcd, natural white
and
0.1W, 1200~1400mcd, white
Old Mar 11, 2013 | 03:29 PM
  #63
lcrazyaznl's Avatar
CL9 ABP
it was a joke he gave me extra stickers so when I had rj wheels added it there
Old Mar 11, 2013 | 10:29 PM
  #64
redpoint's Avatar
and
The dimensions appear 2mm too wide to fit, and the color will likely be just slightly bluish when compared to the warm light of an incandescent. I linked the superbrightleds site and described which size is correct, so if the measurements aren't the same as the link I provided, it won't fit. I'd just go with the ones I linked since I have already tested the fit and color. The price is better too.
Old Mar 17, 2013 | 01:10 AM
  #65
Haha ohh x) thought it was something from RJ lol
Old Jan 7, 2014 | 08:03 AM
  #66
TikkiTakki's Avatar
3+ year update, Radioshack bulbs still working. I'm doing some prep work for a possible N7 install and remembered to update this post!
Old Jan 13, 2014 | 12:06 AM
  #67
lcrazyaznl's Avatar
CL9 ABP
Nice thanks for the update. Sadly I don't have the car anymore.
Old Jan 29, 2014 | 01:48 AM
  #68
guamie's Avatar
7th Gear
sweet DIY! THANKS!
Old Feb 16, 2014 | 12:33 AM
  #69
alxlxiv's Avatar
Really appreciate this! Just changed out the lights on the seat heater toggle switches and the moonroof switch.
The housing for the vsa and moonroof switches was actually easy to pull out with some plastic trim panel tools.
Old Feb 19, 2014 | 10:14 PM
  #70
Blindeye_03's Avatar
I may have to do this after I replace my radio's PCB shortly. I have no lights at all except my drivers side map light, and my passenger's heated seat.
Old Mar 11, 2014 | 03:38 PM
  #71
Replaced some of mine today and thankfully I had ordered extras. Mine may have been overly tight due to buying straight from acura (http://www.acurapartsforless.com/) and so I messed some up installing with a flat head screwdriver that wasnt the right size. I kept slipping and as a result it tore the wire coming from the bulb to wrap around the outside.
What could I use to facilitate install in the future? I still need one for my VSA switch.
Old Mar 25, 2014 | 08:48 AM
  #72
kbh's Avatar
kbh
Anyone know if the window safety lockout switch (next to door lock button on the driver's door armrest) is supposed to be illuminated?
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
