DIY VSA/Moonroof/Heater/ Gear shift lights
#41
Details...
So, trust me guys... you're not the only ones. I've got an 04 with 161K. I've replaced the VSA, Sunroof, both seat heater bulbs and then the third brake light bulb. Now I've got to replace the hazard and the gear selector bulb.
I just buy the OEM bulbs, but than again I am a parts advisor for a Kia dealership so I just pay cost plus ten on the Acura stuff. Even before that, I had no problem paying the $4 for a bulb than go through the effort the OP did.
Its still interesting how all these bulbs are going out for all of us. I had a 96 Integra that never had this problem at a 165K, and an 84 Accord with 287K that didn't either. Oh well...
#42
Center console light
I replaced the bulb and couldnt get the #74H to fit its a bit too big. Used electrical tape to get it held in place.
Now its a screw style so i only put a little layer of electrical tape on so i still was able screw it back in. This is a bright led, I tried it instead of an amber, since I always felt my gearshift light was too warm...
![](https://farm4.static.flickr.com/3096/2676136486_0beef852ed.jpg)
#43
I realize this is an old post and thank you for the time you put into it. I just had my drivers side seat warmer main light go out. I was wondering if you could show a picture of where exactly the first clip is behind the parking break to remove the center console. Also, I'm assuming it is but want to be sure, are the clips located in the same place for the manual and automatic? When you undo the first clip, are you doing it with the flathead vertical or horizontal? Thanks for any extra help you can give me.
http://www.youtube.com/watch?v=b0M0VMWLIFk
posted the video on how remove the center console
vsa/moonroof button
hazard light button
and center cubby
enjoy sorry if it stinks it just a quick vid
vsa/moonroof button
hazard light button
and center cubby
#44
#45
The good people at Lindsay Acura quoted me $6-8 a bulb
so I got the Radio Shack bulbs and they are working out great I paid $4 for 4 bulbs just use tweezers when removing the bulb plastic covers. I found out the easiest way to remove them without tearing the delicate bulb covers is to just smash the old bulb with the butt of your screwdriver and slip the cover onto the replacement bulb.
![what](https://acurazine.com/forums/images/smilies/what.gif)
#49
just updating on the lights that i bought, they work great, they are the exact same size.
only had to switch the blue condom thing, and everything just went in place.
2$ for 5 pre-made is so much better than 5$ for 2 bulbs only
9177741977 (01-17-2013)
#52
07-27-2012 4:59 PMDavu just updating on the lights that i bought, they work great, they are the exact same size.
Where can you get it ? and what is the bulb size ? i cant find it
#53
Where can you get it ? and what is the bulb size ? i cant find it ---what is that blue condom use for i brake that shit i thought it is a blue bulb WTF
#54
http://dx.com/p/0-91w-car-instrument...k-5-pack-47980
the blue cover thing is only to make your lights appear white instead of yellowish
#55
i had it link in a comment right before it, here's the link again
it is Power: DC 14V/0.91W? not hot?
Dose this fit ? 0.56W Indicator Yellow Light Bulbs for Car Audio System (5-Pack)
http://dx.com/p/0-56w-indicator-yell...=47980&u=47983
#56
no idea where you can buy the blue rubber, i don't think there would be much difference without the rubber since its such a small light.
the .91w isnt hot at all, and yes the .56w should fit. but why not buy the premade one?
#57
I wouldn't mess with the rubber caps, OEM bulbs, or buy the Radio Shack bulbs.
Get the NEO3 LEDs from Superbrightleds.com and never replace them again. You have to file the plastic down to get the bulb to fit into some of the sockets.
#58
if my calculation is right, the OE bulb 14v with 200mA is 2.8W, with 400mA each bulb is drawing 5.6W. the .91w only drawing 65mA. correct?
#59
The NEO3 LED bulb in my previous post draws 20mA or 0.28 Watts at 14 Volts.
#61
the original honda bulb is 14v 40mA, Radioshack is 12V 60mA. so the OE consume 0.56W, while Radioshack rated at 0.72W, and placing Radioshack bulb in the TSX at 14V will actually consume ~51mA. .9W is too much... there is another one probably match our application better at .56W HERE notice the colour.. what does this mean?
- Color: Green
- Light color: Yellow
#62
found some 0.1-0.15W LED. Not sure if they would fit TSX. the LED colour maybe bluish without the cover?
0.15W, 1200~1400mcd, natural white
and
0.1W, 1200~1400mcd, white
and
#64
and
and
#65
Really appreciate this! Just changed out the lights on the seat heater toggle switches and the moonroof switch.
The housing for the vsa and moonroof switches was actually easy to pull out with some plastic trim panel tools.
#71
Replaced some of mine today and thankfully I had ordered extras. Mine may have been overly tight due to buying straight from acura (http://www.acurapartsforless.com/) and so I messed some up installing with a flat head screwdriver that wasnt the right size. I kept slipping and as a result it tore the wire coming from the bulb to wrap around the outside.
What could I use to facilitate install in the future? I still need one for my VSA switch.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
