Disconnect Power to Seats
Does anyone know if it would be possible to disconnect power (temporary) to the seat controls? Is there a power harness or something simple to disconnect? I want to avoid anyone changing my seat position.
Bye TSX, hello domestic?
Registered AssHat
Originally Posted by spatel600
HAHAHAHAHAHAHAHAHHAAHHAHAHAHAHAHAHAHAH
SWEET...install a switch...not sure where the harness is, try looking underneath the seat
![Ecstatic](https://acurazine.com/forums/images/smilies/ecstatic.gif)
Originally Posted by VeniceBeachTSX
I'd like it for the car wash.
There's no need for the seat to move, just so somebody can drive an automatic 20 feet...
Moderator Alumnus
Originally Posted by Dan Martin
Just be very careful not to unplug the airbag harness.
If I ever want to unplug the seats to take them off for a good complete carpet wash, obviously, I have to unplug everything to do this, what would I do? Disconnect the battery first?
Photography Nerd
Originally Posted by sauceman
Good point.
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
If you disconnect the seat first, it will cause an airbag error code to be tripped and you'll have to go to the dealer to have it reset.
Photography Nerd
Originally Posted by MarineTSX
Wuts this airbag error code because i just took out both seats and put bride racing seats in all im getting is the seatbelt light.
Unplugged battery and code reset procedure
Hello,
i am about to be away for about 1 month without my car, and was thinking about disconnecting the battery to avoid drainage. i have an alarm and the navi in my car. does anybody know what is the procedure to reset everything when i plug the battery back again.
thank you!
thank you!
Tuxedo Cat
Originally Posted by CGTSX2004
But have you seen some of the guys that work at those carwashes? If they don't move the seat, it'd be like trying to take an 8-foot wide amorphous blob and shove that into your car. Not something I'd like to see.
Usually I find myself having to put the seat back and down after one of them drives it.
Around here they're almost exclusively little Mexican guys, or at the very least, smaller than me.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Photography Nerd
Originally Posted by JTso
Check the fuse box to see if there's a dedicated fuse for the power seat. If so, then simply wire a switch to it instead of cutting up the seat harness.
Just dial 1911
1 Post
![Jesus LOL](https://acurazine.com/forums/images/smilies/jesuslol.gif)
Rep'n Taxbrain.com
The harness is underneath the panels that run down the driver side. You have to take the lower panels off and get to the one that runs vertically in between the front and passenger doors.
I believe I saw the harness for the power seat when I was wiring my TV antennas to the brain of my TV tuner (which is mounted underneath the driver seat). But just pull the fuses like JTso said. This is by far the easiest solution!
rockyboy
01-25-2016 06:00 PM
joflewbyu2
10-08-2015 11:16 AM
