debadging marks
Na man, you won't have a problem.. I didn't heat mine up or any of that, I just doubled up on the floss and took it off. THEN, i used my thumb, yup, my thumb and rubbed off the Goo, took about 30 minutes to do and had a blister on my thumb for 3 days and couldn't use it! true story... Then once I got most of it off you can just spit or use water and a towel and you'll be straight! I don't care what anybody says, you gotta use elbow grease man, just sprayin' some bug and tar remover and rubbin' it ain't gonna work!
i bet ur tsx feels naked without the emblems, hehehehe
i think it looks alot cleaner without it. lol i let my brother use a lyke flat head and he like took it off with that, and we had to spend like an hour using goo off to try to get that shit off lol.
You should be fine to take it off with floss and a little elbow. I've used 3M and Honda adhesive remover personally, but even zippo lighter fluid works to remove the goo if any. Just wash your car after doing it to ensure a smooth surface.
my friend Ian had a problem on his 2003 TLS. When he removed the Acura logo it seems that they put the stickers on before clear coating it so there was a heavy acura indnetion. He's taking it back to the dealer soon.
first day I took off the TSX emblem, took me so long to get that shit off that I had to stop and finish the next day (yesterday). Today I came home from work and was able to get the rest of the TSX off (about time).
I decided to start on the acura emblem. I don't know why but, that shit is just tough. Not sure if I'm not using the right stuff or not rubbing it right. I used WD40 this time and tried goo gone. Both worked the same (not too well). I actually had my blow dryer out there. Worked alright.
Nothing works as good as rubbing the shit out of your fingers until it's hot and hurting like a bitch. Got my first blister on my thumb, then tried to used every other finger. Finishing up acura side tomorrow, it got dark. I got the U R A left. sigh.....
to everyone that got that shit off in 30 mins!!!
AdamC, did you just get your car when you took it off?
Originally posted by 1killercls
Had to be a repaint. Emblems are one of the last items added to the car on the assembly line. (Sorry) :o
For the record, Goo Gone does NOT work on this adhesive! It worked on a vinyl dealer decal that was right above the "ACURA" emblem, but that's it. I ended up using the burning thumb method as well because the Goo Gone wasn't strong enough for the thick gunk under the emblems.
civic4982: I think I remember reading that someone had the same type of problem with their sunroof wind deflector. The guy took it off, and it looked like it had been attatched before the paint dried. Maybe the emblems and the wind deflector use the same type of adhesive and there's some sort of funky chemical reaction going on. I'm sure whoever supplies the adhesive to Honda makes it up in batches...maybe they screwed up a batch?
That is what happened.
TLDude876
12-28-2016 03:18 PM
