Dealership vs private mechanic maintenance
I recently bought a pre-owned 2006 acura tsx and its up for its 45K maintenance. All dealerships in Atlanta recommend a cooling system and brake system flush at 45K, in addition to basic preventative maintenance, i.e. adjust belts, replace filters, bunch of inspections etc. The cheapest a dealership is charging is $375 plus tax. My question is that is it worth it to have your car serviced at a dealership or any local private acura mechanic can do as good a job? In the later case can someone recommend any reliable and honest acura mechanics in the Atlanta metro area?
Thanks!
Thanks!
Modding newbie
You don't need to flush your cooling system, it's perfectly fine till 100,000 or more. You probably should inspect/change the filters, oil, brake fluid, brakes, and belt. Any good mechanic can do the same work and it will be significantly cheaper. I don't know anything about Atlanta so I can't help you there.
hey im in atl and have an 06 too, i take mine to this mechanic in decatur and he's always looked after all my cars. 04 TSX / 05 RL / 06 TL / and now 06 TSX
He is certified and works for nalley lexus. Honest and reliable.
it's a car-drive it
I own a 06 tsx, bought new 11/06. I have all the service done by a acura dealer I think is excellent. I follow the maintenance minder. I recently had a oil/filter change, tire rotation/balance, pressure bled abs and regular brake system and get new brake fluid, changed manual transmission fluid. My car now has almost 104K miles. According to the manual brake fluid should be changed at 3 years (no matter what the mileage) Sorry I am not in Atlanta area
Mechanic contact
still plays with cars
06 and newer TSXes have a maintenance minder which pops up from time to time with a coded indication of a letter and a number - each indication specifies a set of maintenance items. There is no maintenance specified by mileage. The maintenance items are listed in the owners manual, and your Acura dealer has the factory data but will probably try to sell additional service items which may not be needed. Then again, it's your car - do what you wish.
it's a car-drive it
One on the right for me
Thanks!
Thanks!
I think you need to be careful with dealer service. And it depends what you can do on your own and what you cant. Only you can make that call. Oil changes seem to be the same across the board, so anywhere you go its the same price. So I opt for the dealer. Some other stuff, like brake jobs? Dealers RIP you on prices on brake jobs. Almost twice the price. Tires? Dealers are a little more, not too bad.
You just need to shop around, like anything else.
Good side story here. Window motor on wifey's Corolla had to go. Dealer wanted EIGHT HUNDRED BUCKS to fix it. Local window shop wanted Three hundred.
To the OP, if you can find a reliable mechanic that you can trust then go with them, otherwise stick with the dealership. While you may end up paying a bit more, you have more leverage from their management when things go wrong. I had an independent shop diagnose a bad motor mount. Not only didn't they find the motor mount, they charged me $160 to replace the bushings, while changing the bushing damaged my lower ball joints which ran me $360 and then I had to pay a Honda dealer $200 to replace the motor mount.
it's a car-drive it
[QUOTE=npolite;12002276]The items that are not in this system are the brake and coolant fluid among others such as spark plugs etc.
replace engine coolant is a sub code 5
replace spark plugs is a sub code 4
codes have not appeared yet on my tsx-
mrgold35
I usually stick to the regular shops for brakes, tires, alignments/rotations, and exhaust. Any electronic issue or powertrain services I like to save for the dealership.
Keep in mind the TSBs that might be out there. I don't think a local shop will take care those like a dealership.
[QUOTE=nj2pa2nc;12002840]I must have missed it in the manual. It's odd that the coolant is in the MM when the jugs of coolant state 3 years 36,000 miles.
The Sicilian
I have been going to the same mechanic for the last 20+ years. I go to him with my new car & old cars. I only go to the Dealer if HE tells me I should go to the dealer and in 20+ years,that was only one time.
xsilverhawkx
09-28-2015 06:51 PM
