Counter-intuitive Question
Old Apr 19, 2006 | 12:15 PM
TinkyWinky's Avatar
TSX User
This may sound odd, but for the purposes of improving straightline driving characteristics (noise, bumps, potholes ...etc) and even improving highway mpg ...
has anyone thought of switching from the OEM 215/50 -17 to 205/60 -16 wheels/tires?
Would this significantly affect cornering and agility much?
What do you guys think?
Old Apr 19, 2006 | 12:54 PM
VroomVroom's Avatar
Cogito Ergo Idiot
My first guess is that you won't fit 16" wheels around those front rotors.
How about a 215/55 - slightly taller but shoudn't cause any fitment issues - and maybe a slightly lower inflation pressure?
Old Apr 19, 2006 | 01:13 PM
CGTSX2004's Avatar
16" wheels do fit as several people have used them as winter wheels.
If you found a set of wheels that weighed less than stock 17" wheels, went with a tire that was designed with low rolling resistance in mind, and went with the narrower/taller size, you'll see some improvement in both ride quality and fuel mileage, but don't expect the differences to be huge.
Old Apr 19, 2006 | 01:46 PM
micvog's Avatar
CGTSX2004, are you recommending the low rolling resistance and narrower tire for better MPG only? The reason I ask is that when it comes time to replace the OEM tires, I would like to soften the ride a little and I am not concerned about the impact on MPG. So in that case, would I want 215/55 (or even 215/60 assuming they would fit) over 205/60?
Old Apr 19, 2006 | 01:52 PM
CGTSX2004's Avatar
If you want a tire that has a softer ride but maintains the same basic handling characteristics as the OEM tires, you'll want to pick a tire that has a softer sidewall (though the stock Michelin's are already pretty soft). I've never looked for this type of tires, but I'm sure that if you looked around on http://www.Tirerack.com, you could find plenty of ride comfort oriented tires. Keep in mind that any tire that is more biased towards ride comfort will sacrifice some handling.
Old Apr 19, 2006 | 01:53 PM
dom's Avatar
dom
I have that exact size as my winter wheels.
Can't really say how cornering and agility are affected since their winter tires.
Old Apr 19, 2006 | 01:57 PM
narci's Avatar
Canuck
I had this the 205-60-16 on my car for winter and I can tell you that the ride feels rubbery. I'm not sure if it's the actual winter tires that's causing this or what but the car really leans when cornering. It's like you can feel that the sidewall of the tire is giving way.
Old Apr 19, 2006 | 03:08 PM
micvog's Avatar
Thanks... I have already picked out the tire (a Kumho FWIW) but was curious if getting a higher-profile tire would help as well.
Sorry for the thread hi-jack.
Old Apr 19, 2006 | 03:22 PM
ianS's Avatar
I will stay away from kumho as much as I can. They are harsh, noisy and easy to have tunma.
Old Apr 19, 2006 | 04:18 PM
VroomVroom's Avatar
Cogito Ergo Idiot
Cool beans on the 16's fitting....see what I know?
For what it's worth, on my '02 Camry I went from 205/60-16 stockers to 215/50-17 (sound familiar?) Yokohama YK-420's. There was a distinct difference - for the worse - over harsh bumps. Not sure what that says about a switch in the other direction, but I've got to think it'd be noticeable.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
