Cold start problem please help
Old Oct 21, 2017 | 01:57 AM
Daniel Ferrone's Avatar
I have a 2004 Acura TSX. 4cyl automatic. So this only seems to happen the first time. Meaning once it starts. Every other time I need to start throughout the day there's no issue but a very slight lag.
Anyway. So if I go to start the car in the morning. It'll crank 3 or 4 times then completely shut off. This goes on about 3 or 4 tries then it starts. As I try starting the car no check engine, battery, or any other light pop up on my dash. I checked my battery. Crank Amps were really low. Bought a new battery. Same issue. Got my starter tested. Everything checks out. And unless my check engine light is on which its not. An obd reader is useless please help
Old Oct 21, 2017 | 10:20 AM
TexasHonda's Avatar
A fuel delivery problem; weak pump, blocked fuel strainer, etc would cause your symptoms w/o setting a code. Suggest having fuel pressure measured (cold engine). Special fitting required to perform fuel pressure check. New fuel pump may be necessary if low fuel pressure is confirmed.
good luck
