Clicking noise from dead stop?
I just hit 10k on the odo. The car runs great but there seems to be a clicking or light thunking noise when I hit the gas pedal from a stop. Anyone run into this problem? Im starting to hear some rattles too.
Originally Posted by TheDukeZip
Is it just the first time after you start the car or every time from a dead stop?
The ABS only does a self check when you drive your car over 5 miles per hour, right after you start it. Once you cycle the ignition off and then on again, it will check the ABS again.
Also - FYI, (if you can even hear it, I could on my prelude) the ABS check sounds more like a pump turning on then a clunking sound.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
