Center Stack Backlighting Failure!
Old Jun 9, 2004 | 05:57 PM
sveet's Avatar
I am really starting to wonder if this car is put together that great.
Misc. rattles, notchy cluch pedal, and now the clock, radio, and climate control back lighting has all failed. Can't read them at all.
Yet another trip to the dealer....................
PS : I am not so sure of Lexus either. My '04 RX330 had the brake booster fail at under 1000 miles(rattles, too!). What gives??? I thought these Asian premium brands were supposed to be the real deal??? If this crap keeps up they may actually be worse than my last two domestics, a Jeep and a Contour. I really hope not!
Old Jun 9, 2004 | 06:01 PM
jlukja's Avatar
You're not the only one. Do a search on "center console" and you'll find a couple of threads on the subject. Sorry to hear about your troubles.
Old Jun 9, 2004 | 10:00 PM
prolix21's Avatar
It seems that most dealers are aware of the center console issue, mine was a pretty quick fix. Parts took a while to get in, but other than that they only had the care for a couple hours to diagnose and then maybe half a day to install the new parts (a completely new center console). Zero problems with the new unit and I couldn't even tell they replaced it (alignment and whatnot are perfect)
Good luck
Old Jun 9, 2004 | 10:05 PM
jiggaman's Avatar
I spend 2 much time here
you mentioned a notchy clutch pedal. could you describe that some more. cuz my clutch pedal has been feeling somewhat notchy for a while now. planning on having it looked at my next service, i've also got a new rattle sound in my drivers side door which is not stereo related. i actually only hear it when my volume is low.
Old Jun 9, 2004 | 10:12 PM
sveet's Avatar
I could feel a distinct click type grabbing as I would push in or let out the clutch. I was inconsistent. Sometimes up high, other times down low. I figured it was stiction in a pivot, etc... NOPE..... New Master Clutch Cylinder..........
Sorry all I didn't search the center console thing before I posted. I see this is a fairly commen, MAJOR problem. I was hoping it was a wire, but it sounds like major dash surgery.........
MrHeeltoe
20
Feb 23, 2023 01:54 PM
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
