CAr is back from shop, headlight not leveled.
So, do you like...stuff?
The car is back from the shop and overall the job looks good. The hood, front bumper and left headlight were all replaced. The paint job is good. However, the left headlight is not leveled correctly. It is slightly lower than it is supposed to be. Does anyone know where the levelers are? I looked briefly and couldnt find them.
EDIT: I know that the HID profile has the right side higher than the left. BUT i can clearly see two distinct lines from each headlight, whereas before the work there was one continuous line.
I can clearly see 2 lines also when I am shining them on something close...if it's on something further away it looks more like one line. Take it back to Acura and have them raise the driver side a bit.
I remember reading somewhere that the left beam is supposed to be slightly lower than the right beam in order to reduce glare to on-coming drivers. If I remember correctly, my previous car, Integra, had the same setup since it is also a projector beam headlight.
I see 2 distinct lines. The left is def lower..and I can see it. I assumed this was normal. I get people high beaming me as it is, so I dont think I want to raise it any more.
I think Roger is aware that the drivers side will be lower. The question is when you drive can you see a distinct lower line on the left. In my case I do. Of course its got to be fairly dark to see it, but its definately there.
That explains it...I thought it wasn't set up right.
I see that the left one is lower, but what is this distinct line you speak of? I know there's a "stair-step" from the right to the left, but I don't really understand what you mean by a distinct line.
Do you mean both lights dont' "blend" in together?
my left headbeam is lower than my right by 2-3 inches so it looks like a little mini stair-step...at first i thought this was something to needed to be fixed, but from other posts on this thread this seems to be normal
I am aware of the "stair step" from right to left (higher to lower, in three intervals) to not blind oncoming traffic. But my left HID clearly is pointed at the ground where the right one is still stock. I recently hit a deer and the left HID was completely smashed, and replaced with a new unit. The new unit is obviously not properly aligned, so I was asking if anyone knew where the adjustments were (i.e. left to right, up and down). I will look harder when i go home tonight. I will have the dealer fix it if nessecary, but i was hoping this is a do-it-yourself job.
thanks for the replies.
Thanks for the info folks - I thought my car was the only one with the driver side headlight lower than the right - you can tell the 2 distinct lines pretty easily.
Good posts and great forum!!!
tman570
06-11-2019 07:56 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
