brake job
brake job
Hi all,
I def think i need new brakes as I am usually hard on the brakes and I now have to really depress the pedal alot.
I have an 05 TSX w/ 28K miles on it. Do you think i need front AND back brake pads or just front?
any assistance would be great.
Thanks,
Jonathan
Thanks,
Jonathan
Usually at 28k- you can resurface the front rotors and bleed/flush the brake fluid. Brake fluid flush is good thing to do once a year or more if you really drive hard!
Valvoline Synthetic DOT4 used by many acura owners
Normally the rears last twice as long as the front
If you have worn the rotors heavily and they are scored or damaged, upgrade to some awesome RacingBrake rotors.
I would run HAWK HPS brake pads regardless of what rotor you are using- they are great for the enthusiastic driver
Acurazine sponsoring vendor MrHeelToe has a huge selection of TSX go fast
and stop even faster-goodies- check the website- special deals for aziners
www.heeltoeauto.com
and the rotor pads combo
http://heeltoeauto.com/Acurazine-Rac...s-pr-2321.html
www.heeltoeauto.com
Driver/Detailer
No, if he doesn't have brake shuddering, then he doesn't need to machine the discs. Machining it will just make it thinner and more succeptible to warping. On the TSX, if you do mostly highway miles, the rears wear out first before the fronts. If you do city miles, then they wear evenly.
Former Sponsor
Originally Posted by Red Devil 1
Hi all,
Thanks,
Jonathan
Thanks,
Jonathan
If you need a better than OE setup look into ROTORA slotted rotors.
https://acurazine.com/forums/sponsored-sales-group-buys-10/rotora-slotted-drilled-slotted-rotors-special-cl-tl-tsx-324531/
GWEEDOspeedo
01-15-2016 10:39 PM
