Battery Indicator
Old Jul 17, 2006 | 11:36 AM
parag_a2z's Avatar
Battery Indicator
Well, I have been using my Razr linked with the Bluetooth in the car, with absolutely no probs. I am enjoying it.
But just as i was going thru the manual this weekend, I found out that the display should show you the phone battery indicator as well with the signal strength on the panel display. I am seeing the signal strength but not the battery life.
Is anyone of you able to see the battery life on the front panel, if so, is there anything special that you did while pairing up the phone, or wat?
Old Jul 17, 2006 | 12:21 PM
parag_a2z's Avatar
20 views, no reply...........guys n gals
Old Jul 17, 2006 | 12:23 PM
kboosman00's Avatar
no0bIe
Wish I had bluetooth in my 04 . I guess I'm stuck w/ my headset...
Old Jul 17, 2006 | 12:40 PM
cibs's Avatar
patience man, just cuz noone replies maybe they just don't know the answer to your question..
anyways it's a function of the phone to show the battery life on the MID, i'm guessing that the RAZR isn't compatible with that feature, i have the V635i and i don't get battery life shown on the MID either, thankfully I do get signal strength though. Apparently some people dont' even get signal strength shown on their MID.
there's a website that acura has (handsfreelink.com) that you can go to see what phones are compatible with the Handsfree link and what features they work with...
Old Jul 17, 2006 | 12:48 PM
ZhenyaF's Avatar
Off roading in his
i had a motorola i870 - it didnt show neither the battery life nor the signal. With the rarz it shows only the battery signal. As Cibs said, different phones have different compatibility levels
Old Jul 17, 2006 | 01:26 PM
Jeff The Pianist's Avatar
same here...Nokia 6230...gets nothing on the MID but phone works great!
Old Jul 17, 2006 | 03:23 PM
sidssp's Avatar
According to the handsfreelink.com web site, battery levels indicator is not supported for the Rarz.
Old Jul 17, 2006 | 03:25 PM
parag_a2z's Avatar
Thanks Dude, I just noticed that as well. How much does it take for Motorola, to support that feature................
Old Jul 17, 2006 | 03:38 PM
PWPTSX's Avatar
i had motorola SLVR, and it does display the battery indicator as well as the signal strength there..........
Old Jul 17, 2006 | 04:10 PM
sidssp's Avatar
Don't know. Same for my Treo 650. It seems like a common problem. But it shouldn't matter much if you use car kit to power the phone.
Old Jul 17, 2006 | 09:10 PM
angrycamel's Avatar
I have the comparable A900 from Samsung. Its a lot like the razr. Here is a thread a posted about it in the audio/video section: https://acurazine.com/forums/audio-video-electronics-navigation-22/samsung-a900-06-tsx-bluetooth-compatability-343877/
I have experienced the same things though.
Old Jul 17, 2006 | 10:18 PM
rambalu80's Avatar
NBP6MTTSX
I have a Nokis N80 & it displays neither the battery life nor the signal strength, but with my Sony Ericsson K750i, I can see both battery life & signal strength!
Old Jul 18, 2006 | 08:32 PM
gecko23's Avatar
Former Boost Junkie
LG VX8300 here. shows both battery and signal
Old Jul 18, 2006 | 10:24 PM
SoCaliTrojan's Avatar
Let me help you!
Both the sony ericsson s710a and w600i have full compatibility. I see both battery and signal level. (The w600i had to be flashed to the previous version though, since the current version isn't supported)
I believe the compatibility problem lies in each manufacturer's bluetooth implementation for a certain model. They can decide which information should be made available to bluetooth devices.
You might want to look into some cell phone forums to see if there's a flash you can use on your phone. But it's a dangerous process...be glad your phone actually works
Old Jul 19, 2006 | 04:38 PM
swirlie's Avatar
Swinger, just ask Lindy
It depends on which model and implementation of the RAZR you have. I have a RAZR v3c from Bell Mobility and I get both the signal and battery. Different carriers may have the "same" model, but the implementations will be slightly different. The v3c from Cingular has several differences from the one from Bell or Verizon or any other carrier.
Old Jul 19, 2006 | 04:51 PM
bradykp's Avatar
Still Lovin my 06
true, the best thing you can do is contact your carrier's customer service and report this as a problem. if you're lucky and other people do the same thing, they may include the compatibility in the next software upgrade for your phone. every carrier has different software for their phone, that explains why maybe a cingular razr would work and verizon wouldn't or the reverse. i have the lg vx8100, and according to the site it doesnt show battery life, but it does. sometimes it doesnt though, so maybe it's something quirky with the 8100.
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
h22lude
Sep 27, 2015 06:22 PM
