Aux cable for iPod--I am such a jackass!
Ok..I feel really stupid to say that I have had my TSX for a year now and just recently discovered that I can connect my iPod to the car with a $10 cable through the aux jack (which I did not know existed.)
Am I crazy or did someone here have a whole thread about tearing out the center and wiring their iPod in the car? I thought it would be a big huge process, but after READING THE MANUAL I realized that the pod could be connected in seconds.
Ok...so call me a dumbass and let's get on with it. Thank you Captain Obvious!!
Rep'n Taxbrain.com
Haha...Well the 04/05 TSX didn't have the AUX adapter, so yeah we use to have to tear the dash part.
The 06 TSX has the nice AUX in port. Too bad you didn't find it until now, but hey at least you found it...haha It's better than finding it the day before you're about to sell the car.
The 06's and up had the AUX cable built in. 04 and 05 needed some special rigging. I was on the fence about getting a TSX, but once I saw the AUX cable and Bluetooth integration I was sold. For some reason the alternative was an S2000 for me, even though the cars aren't in the same category.
Ok..I feel a little better knowing that someone did in fact probably tear open the dash and post about it. I just should have read more carefully because he was prob driving an 04 or 05.
So now I'm happy that I found it and, yes, bluetooth was a major, major selling point for me as well. However, I kinda hate using it. I guess I'm just what my husband (who is a computer tech) would call a "12:00 flasher".
(as a post script: Hubby did not read the damn manual either and had an iPod way before I did. I think that makes him a bigger jackass. I will remind him of this when he gets home tonight. )
Even though I have an 06 with this jack, I still installed an aux ipod solution, since it has a docking cable connection to the ipod instead of the standard headphone jack. This enables line-out quality audio (better than headphones) and allows the steering wheel controls to work with the ipod, and charge it while it plays. Just saying, there is still a reason to install a full ipod interface for some people like me who prefer to have it like that.
Earth-bound misfit
I did the same, and agree - the sound quality is much better.
Registered Car Nut
Interesting... i didn't think that the sound quality would be that much better. I think that the sound quality is OK with the jack, as long as the volume is maxed on the iPod. If I ever install an aux ipod kit, it will likely be so I can use the steering wheel controls, instead of having to use the iPod controls...
Which one did you guys install? USASpec ?
my acura sanctuary
you don't need to install the USAspec type to get better sound quality (SQ) you can get line out level by using a dock or an appropriate ipod dock port cable. this route doesn't provide the steering wheel controls for track skip
I have this in my car right now.
http://www.sendstation.com/us/produc...neout-usb.html
line level output, plus I have it connected to a car charger that accepts a usb cord, so I'm charging it also. Just can't use steering wheel controls, but i have my nano on a short lease, so i can change songs pretty easily. relatively inexpensive solution, and you don't need to install anything. great sound quality.
if musiclink worked like it was supposed to, and displayed id3 tags on the navi, that would've been the best way to go. oh well.
I recently bought an adapter similar to this one (mine is from Belkin):
http://www.sik.com/imp.php
I don't get the steering wheel controls but I do get the excellent audio hookup and the charging.
PS: Love this forum - leased an 07 ASM Quartz AT non-Nav three few weeks ago.
Originally Posted by alucardx
the belkin has a built in volume slider as well so you can further tweak the volume in relation to the TSX headunit volume, didn't see a volume knob on the sik model.
I do kind of like the separate/detachable cables of the SiK.
Here is the setup that I have and I think it works pretty well (minus being able to see my ipod display):
Belkin Auto Kit for iPod w/ Dock Connector:
http://catalog.belkin.com/IWCatProdu...duct_Id=149006
Griffin AirClick:
http://www.griffintechnology.com/products/airclick/
In this setup I can charge my iPod and I can change/pause/play, etc the songs with the Griffin AirClick. What is also nice about the Belkin Auto Kit is when you turn off the car, it pauses your iPod for your automatically.
Griffin AirClick:
I didnt find out that my 06 Had a ZUX port till after i bought it. I was dumfounded when I saw that AUX port sitting under the Arm rest. I eneded buying the Belkin Auto Kit and then the Tune Dock. its a great set up when XM or the CDs dont fit the bill
as a follow up.. the AUX plug in my car from day one seems real sensitive the 1/8" patch cable i'm using right now. if it gets bumped, or i do a hard turn and my ipod touches the cable it typically moves almost all audio to the L channel and i have to wiggle the cable to get it back to stereo. also while wiggling i get the typcial static'y scratching sound you hear from over used headphone jacks that are real touchy.
this came up in another thread some time ago and the guy said he cut down the plastic 'end' on his cable so the AUX port has more room to fully insert the metal into.
any one else?
any one else?
No Longer a Poseur
any one else?
any one else?
I'd agree that the plug is too large a diameter and the thing isn't seating into the jack all the way. Radio Shack has some not-super-thick-connector cables, and they sound decent.....
I'm going to have to get me one of those Belkins, since I've got the AirClick setup, but with a Monster charger...and I will occasionally forget to pause the iPod before leaving the car.....
im still curious to know of the 06-07 aux is a part that is easily ordered and a direct plug in play item that will plug right into the 05 radio vs getting a usaspec.. has anyone looked into the differences
New at this also, I just got a ipod, how do i and where do i get the aux cable from? do i need the whole kit wid the cigarette plug? please explain in detail thanks everyone.
Vic
Poser / Fanboi
Vic
Vic
You can pay extra for the "gold plated ends" - the Radio Shack tech offered that one to me first for $13 - but I wouldn't bother.
Make a hole, coming thru!
They intro'ed the AUX port in 2006, so don't go crazy trying to find it if you own a 2004 or 2005. As always, read your manual once in a while.
Originally Posted by hunterk1
Go to your local Radio Shack and buy a 3.5mm male to 3.5mm male - like this one, for about $6. Or buy the one at the link for $6+shipping.
In my '04 (precusor to my '06 RL) I had the DICE unit - it worked well. In the '08 TSX I use the Belkin car charger with the aux jack and the sound is just as good as my DICE unit. I was expecting a dimenished quality but was pleasantly surprised.
Not bad ... I hear that the iPod interface is better, but I'd be surprised if it was digital (as HDMI interfaces for DVD/TV devices carry digital information to be decoded by the playback device). Probably just a 2-channel analog pass-through. I find that with my Inno, my phone, my PDA, depending on the device, I have to set the volume up to match that of FM radio and CDs (10 is comfy, 15 is comfortably loud, 20 is filling the car with sound).
BTW, Monster makes good cables, but at retail outlets they run $20 or more; some packaged and priced to attract the squandering iPod shopper. More reasonbly priced on Amazon. I find that their "THX" line of cables, which run kinda cheap despite what they're touted to be, are very sturdy and resilient. Cheaper cables without gold-plated contacts tend to get grungy and perhaps not conduct the audio quite as well. But I think you'd have to have an audiophile's ears or collection of toys to tell the difference. I use cords with gold contacts to just avoid the noise that cruft and corrosion can impart.
Well what's great about it is you can take your S50 or Stiletto and listen to Stern on the way in to work if you record it. You obviuosly could listen live but I'm not putting that antenna anywhere near my paint.
which belkin charger? can you gimme a link? so you prefer this alternative vs. the cables?
thanks,
Vic
so ur saying i dont need the belkin kit when I could just plug a cable in? or do i need both? im confused? what do u guys suggest? I dont want it sounding like crap either. thanks every1.
-Vic
-Vic
Registered Car Nut
All you need is the 3.5mm cable, and potentially a charger for the iPod, depending how often you take it out of the car to charge... mine practically lives in the centre console, except when i want to change music on it. So I got a $20 charger and I'm good to go!
Sound quality is as good as can be!
It looks like there's an audio out adapter on this cord, but the description indicates it's "a DC input jack, which [is] used with the Belkin F8V3080-APL TuneCast II Mobile FM Transmitter that includes a DC power cable." So even this might be overkill. You don't need any FM doohickey, you've got an AUX cable right there.
I'd shop at Target and Radio Shack and elsewhere and see if someone makes a combo charger and analog stereo out.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
