Auto tensioner replacement?
Old 02-06-2018, 12:32 PM
9000revs's Avatar
Around what mileage is it better to replace it? Looking at a 07 with 108k miles and tensioner or water pump was not done.
2004-2008 TSX Maintenance Schedule up to 300k miles! - Acura TSX Forum
Old 02-06-2018, 01:04 PM
BROlando's Avatar
Received 1,184 Likes on 891 Posts
My water pump schedule is every 100K miles. Along with coolant (obviously), and spark plugs.
I did not bother with timing chain or tensioner replacement. Mine is fine...not stretched or rattling.
The BELT tensioner should be replaced when it becomes rattly. Mine started making noise at like 120K miles or something. I replaced it. Took 20mins.
Old 02-06-2018, 06:32 PM
TexasHonda's Avatar
Both water pump and belt tensioner give ample warning (noise for both and leaking for pump), so not absolutely necessary to replace at mileage interval.
good luck
Old 02-06-2018, 07:52 PM
9000revs's Avatar
Ok thanks.
Old 03-25-2018, 11:22 PM
k20trick's Avatar
You can hear the noise, the pump and tensioner will make different noises, mine is starting to make that noise and on the to do list, but not a priority until its definitely evident.
3GTLCHICK
05-23-2019 09:50 AM
astig
1G RDX Problems & Fixes
07-29-2015 12:08 PM
chris03tl
01-11-2014 02:50 PM
kbh
1G TSX Problems & Fixes
12-14-2012 09:09 AM
axleback
04-03-2007 12:37 PM
Quick Reply: Auto tensioner replacement?
