Armrest Tray Lock - HELP
Armrest tray lock repair
I broke the tray lock in the armrest and am trying to fix it. I have detached the armrest from the console, and removed all the screws I can find. However, I have not gained any ground on accessing the broken one (#20 in the below link).
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Before prying the pieces apart (and breaking something else), I wanted to find out if anyone knows where I need to go from here.
Any advice or links for directions would be greatly appreciated,
PLEASE HELP: This was an original post from LITHERHINO - I got the same problem
You will need a large flat-tip screwdriver and insert it into the opening where your broken clip(s) is (#20 and #19), gently push it to release the hooks (inside) that hold #11 to the actual armrest piece. Once the hooks are released, slide the lower portion forward (away from the hinge), and you should have separated them.
Make a hole, coming thru!
I journeyed back in the Wayback Machine to find help dismantling the armrest (I also had to replace a broken LOCK, TRAY), and took some pics to help illustrate this problem for future readers. See my DIY post here.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
