any idea how to mount this?............................
http://cgi.ebay.com/DELPHI-ROADY-XT-...QQcmdZViewItem
I think this one can only be mounted into the cradle... not double side tape the whole unit onto any surface.... any idea how to mount this on tsx?.... other than takeing away an AC vent?...
do you definitly want that system. are you trying to use it in two cars cause if not there are a bunch of other units that can be installed in the sungalss holder and conceled and look ten times better. I was going to do that till I won a XM MyFi now i just you the vent mount.
There are many-many ways to install aftermarket Satellite radio into the TSX.
First you need to decide which service, XM or Sirius.....
After that you need to look at all the gear. Crutchfield has a fairly good list.
As a word of advice, be sure you use either a hard wired FM modulator, (you can tap into the OE antenna plug behind the CD pocket off the right in the main wire harness,) or use some type of AUX. adapter for the OE Radio.
The wireless FM modlators on many PNP's are really not worth a **** IMO.
Several companies even offer clips to install many things to the dash or console. Pro-clips sells a console bracket for the TSX and I'm sure others sell them as well. I've seen a dash bracket as well for near the CD cubby pocket.
do a search many of us have aftermarket SAT radio setups.
You should also look at some of the other XM receivers. I think some of them have audio buffering, so you can rewind a song if you want to hear it again.Pioneer has also just released a portable tuner similar to the MyFi.
Anything you could tell me about the MyFi would be appreciated. The reviews I've read on other sites are very mixed -- some people love it, others say the sound quality is no good.
joflewbyu2
Oct 8, 2015 11:16 AM
