Any gear ratio changes in the MT for 06?
A common complaint in the 04-05 models was that the 1-2 gear spacing was so large it made it difficult to make this shift smoothly.
Does anyone know if any of the gear ratios have been tweaked for 06? (I've seen Acura do this before in the middle of a model cycle, lest anyone accuse me of being nuts...
Hmm, thinking about going for the manual. Not too familiar with driving manual though, but am willing to learn based on recommendations from AZ. What do you mean by a gear being too short or too tall? I've heard things like 6th gear is too tall and so the gas mileage isn't great on the highway, but what does that mean exactly? Thanks =)
Short gear ratio=RPM high for a given speed
Tall=RPM low for a given speed (good for economy, bad for performance).
On the TSX, you lose like 3000 RPMs when shifting from 1st to 2nd, so you lose a huge amount of power doing this shift and it doesn't feel smooth at all. 6th gear is set a bit short compared to other cars, but I like being able to pass on the freeway without shifting. Besides, Sauceman and others have shown that you can still get outstanding fuel economy with the 6MT.
What!?
Oops, had short and tall reversed. Thanks =)
So, what are some shift points for a manual newbie like myself? Like, minimum rpm to shift up into next gear so you don't stall, and maximum to downshift so you don't blow your engine? And when going after performance vs good fuel economy?
take a look at this .pdf file. pretty good information here...
http://www.littlemini.us/technical/heelandtoe/learnstick.pdf#search='how%20to%20drive%20stick'
At what speed should you shift to second? It depends on the car, but in
general each gear has a good range:
First from 0 to 15 MPH tops
Second 3 to 25 MPH
Third 15 to 45 MPH
Fourth 30 to 65 MPH
Fifth 45 to ??? MPH
Usually you shift up when you are at the halfway to 3/4 point between the
two extremes. First gear is really only to get you going. In fact, it is very
easy to start the car in second gear - although don't try this until you get
good handle on the whole process as it is tougher on the disk plates.
Second 3 to 25 MPH
Third 15 to 45 MPH
Fourth 30 to 65 MPH
Fifth 45 to ??? MPH
Do you have a 6 speed TSX (or plan on getting one)?
Have you ever driven manual?
I wouldn't worry about shift points until you actually have some hands on experience with driving a manual car. Over-thinking it will only make things worse.
And even then, you'll realize that you rarely look at the tach during driving. Just listen to the engine.
I don't even know if it's possible to stall other than in first. You might bog the engine if you're RPM's are too low, but you won't stall it if you're in motion.
Originally Posted by psteng19
It depends on the car. You just get a feel for it.
But I guess I need to master the sunroof first huh
Originally Posted by MyopicPaideia
Wait a minute, you really lose 3,000 RPMs on the 1-2 shift? That can't be right, so you HAVE to rev the engine to 5500 just to not completely bog it going into 2nd gear (Theoretical 2500 RPM)? That seems recauculous to me...
Hondata's reflash aims to address this 'problem' by lowering the VTEC switchover RPM and raising the redline. Someone with Hondata can problem tell you how successful the reflash is at smoothing out the 1-2 shift.
Originally Posted by aaronng
That's not right. A Hondata'd 6MT TSX when shifted at 7600rpm lands at 5000rpm.
It's also a little annoying for regular daily driving that the difference between 1 and 2 is so large. Just makes it harder to smoothly accelerate.
On the positive side, I have no problems with the shorter 6th gearing. I still average 32 or 33 mpg on the highway and the car is hardly broken in yet.
Originally Posted by BulldogHockey
Doesn't Hondata lower the VTEC to 5000 from 6000? It's one of the reasons I'd consider going for it if they ever release for '06.
If you are shifting at redline, why would smoothness be a concern? If shifting at 3000-4000rpm was not smooth, that would be a more valid complaint.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
guyvelella
Sep 30, 2015 11:02 PM
AcuraKidd
Sep 26, 2015 04:10 PM
