Air struts from Truhart.
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
Hello, I just made an account and am new to the use of forums so apologies in advance if my writing format is not correct.
So I own a 04 TSX and have been thinking about getting it bagged. Browsing around on the internet, I've had trouble finding places that had air struts that were compatible with my car until I found this brand called Truhart. At the same time, I trying to get in contact with Accuair to ask about their e-Level Management system and am waiting for a response from them. I've looked around for reviews on it and have seen some for spring coilovers but none about air struts.
Does anyone have these Truhart air struts on their car?
Thanks.
Thanks.
Thanks.
Thanks.
I'll be back in a few weeks with some feedback, but if you really can't wait to get them, talk to Jerry McGovern at Tru Hart for some good customer service and any questions you have. Later.
The whole kit with the manual management? I just heard from someone on Facebook that the management that comes with the kit will make the car ride like crap. I don't know how accurate he is, but I would definitely advise you to go with a digital management if you can. How much are you paying for the whole set up?
Truhart air struts
Hey I have the truhart struts wit accuair switch speed the ride is good pretty decent. IF you drive all the way up youll be bouncing all over the place especially when you hit those bumpy roads but if you drive at a regular drop height you'll be fine still a little bouncy depending on where you live but I love em. and I daily drive with em
And.
When you say regular drop height, about how much of a drop in inches is that?
Thanks man.
Well yeah the whole kit for now, maybe later down the road I'll upgrade to a digital management. . I would only want to know what psi you guys ride on? Also how much down or up did u move the lower part of the assembly to get to ride height? And how it rides at the psi used for dd? So many questions lol my kit hasn't arrive yet, should next week tho
I'm not maxed dropped may be about 85% I can still go low and body drop it. I drive with about 200 psi in the tank. The ride with these bags are bouncy thoughi need to find a way to soften the ride. When are yours coming in?
I started to install them this weekend, but didn't finish yet due to needing miscellaneous fittings etc.
Did you find a sweet spot yet for comfort and not so much bounce?
Thanks dude 19s g37 wheels yea I can lower the front more not the back. I found a comfortable ride hight but I need to upgrade to the elevel I need that preset control. Did you get yours yet?
How do you know when to stop airing out and not break anything since you don't have presets?
Did you do the install yourself?
Hey guys I need help! I just installed the truhart kit on my 3g Tl, however the front doesn't go up! N no i don't have leaks.. what psi pressure switch are you guys running? Because I can have the car on jack stands and air the front up take the car off stands and it will be high, once I air it out and try to inflat it, it's as if the car is too heavy for it to lift . Any help? The rear works perfect 👌
I had the same issue are you running accuair for air management? The problem is our cars are heavy in the front that's why it does that. You need to run more air in the tank. 200 psi is what I'm running.I need to know what air management system you have? And do you have a pressure switch?
Well right now I have manual switches , however I ordered autopilot v2 management should come soon. As for the pressure switch I do have one, this switch only allows me to go up to 140psi and at that psi the front doesn't even lift! Do you believe I need a 200psi pressure I'm sure switch?
Sounds good bro, let me order that asap, I shouldn't damage the bags with that 200psi right? I also believe my tank is rated for 200psi .. that shouldn't be a problem correct?
Nah it won't damage your just not getting enough air To raise the front . I was kinda worried too with more air I rode for a month now no prob. I was riding mine with 120psi for 2 weeks and was scared to air down cause it takes so long to get up! How many gallons is your tank?
Bagged tsx ride height pressure
lanechanger
10-13-2015 10:56 AM
