Air Condition question
Old Nov 13, 2006 | 12:24 PM
9ballron's Avatar
Hey you guys,
Just wondering if you guys are irritated with the noise of the a/c. I have a 06' TSX auto w/nav and I feel like it's just as loud as my 94' Accord. Is this noise common? Just wondering. Thanks!!!
Old Nov 13, 2006 | 12:38 PM
LuvMyTSX's Avatar
Noise? What noise?
Old Nov 13, 2006 | 12:39 PM
tinter's Avatar
turn up the music
Old Nov 13, 2006 | 12:44 PM
jaehshim's Avatar
a/c or heater?
the climate control in general is quiet upto fanspeed 2
i really never use it upto fanspeed 2 or 3.
Old Nov 13, 2006 | 02:14 PM
bradykp's Avatar
Still Lovin my 06
i don't notice any noises, just the purr of the air blowing. anything 2 or below is basically inaudible.
Old Nov 13, 2006 | 02:29 PM
dwest1023's Avatar
what he said
Old Nov 13, 2006 | 02:58 PM
dj Dozhe's Avatar
6MT or Death
^^ Same here. No noise.
Old Nov 13, 2006 | 10:43 PM
ChrismanTSX's Avatar
Registered Car Nut
I don't notice any noise either... sounds like you may have a problem!
Old Nov 13, 2006 | 10:46 PM
EuRTSX's Avatar
Your hearing must be very sensitive. My hearing is very sensitive as well. It does get a bit loud for me as well sometimes, even at 2, that it bothers me and I shut it off. I tend to hear unnecessary things.
Old Nov 13, 2006 | 10:56 PM
Registered Car Nut
Originally Posted by tinter
turn up the music
Old Nov 13, 2006 | 11:17 PM
SoCaliTrojan's Avatar
Let me help you!
I try to protect my hearing...I don't play music loud. I haven't heard anything wrong with the a/c...2 and below is pleasant and not so noticeable. 3 and above is somewhat loud only because it's moving tons of air
Old Nov 14, 2006 | 06:11 PM
9ballron's Avatar
No...not the air blowing through the vents. I believe it's the fan turning off and on. I only hear this when using the a/c not heater. Is that normal? Or should I have it taken look at?
Old Nov 14, 2006 | 06:15 PM
helraiser's Avatar
no noise - although in really hot weather you can feel the a/c engage/disengage a the car will slow/speed up.
Old Nov 14, 2006 | 07:51 PM
Grifter's Avatar
are you running it at full blast?
Old Nov 14, 2006 | 08:35 PM
derbaff's Avatar
You're probably hearing the compresser kicking on and off. My old car I could always tell when the compressor kicked in because it made the car louder and caused a slight vibration. In the TSX however, I can't really tell when it kicks in. Maybe you should mention it to the dealer.
Old Nov 14, 2006 | 09:34 PM
aaronng's Avatar
Driver/Detailer
At high fan speeds, the fan bearing noise is irritating! Only started happening after 1.5 years.
Old Nov 14, 2006 | 10:31 PM
slo007's Avatar
Master in Science
Mine has zero noise. (04)
Old Nov 14, 2006 | 10:33 PM
slo007's Avatar
Master in Science
Could it be a ghost?
Old Nov 16, 2006 | 08:52 PM
9ballron's Avatar
nope. even at 1 I can hear the compressor. I'll ask the dealer about it.
Old Nov 16, 2006 | 08:53 PM
9ballron's Avatar
Yeah!!! That's what it probably is but on mine I do hear the compressor. I'll ask the dealer about it. Thanks.
Old Nov 16, 2006 | 08:57 PM
Registered Car Nut
I have that in my 1998 Path. The compressor makes a noise, which I've been thinking sounds like a bearing gone bad... I don't hear a thing on my TSX though. The only thing I'll ever hear/feel is that the engine idle speed will go up a couple of hundred revs to handle the extra load of the compressor. Have it checked out, this doesn't sound normal at all!
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
datadr
Sep 12, 2015 09:12 PM
Nicho863
Sep 3, 2015 09:16 PM
