Hey you guys,
Just wondering if you guys are irritated with the noise of the a/c. I have a 06' TSX auto w/nav and I feel like it's just as loud as my 94' Accord. Is this noise common? Just wondering. Thanks!!!
Still Lovin my 06
i don't notice any noises, just the purr of the air blowing. anything 2 or below is basically inaudible.
Quote:
what he said
EuRTSX
close
- Join DateFeb 2006
- LocationDistrict of Corruption
- Age38
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:106 Times in 70 Posts
Your hearing must be very sensitive. My hearing is very sensitive as well. It does get a bit loud for me as well sometimes, even at 2, that it bothers me and I shut it off. I tend to hear unnecessary things.
Let me help you!
I try to protect my hearing...I don't play music loud. I haven't heard anything wrong with the a/c...2 and below is pleasant and not so noticeable. 3 and above is somewhat loud only because it's moving tons of air
No...not the air blowing through the vents. I believe it's the fan turning off and on. I only hear this when using the a/c not heater. Is that normal? Or should I have it taken look at?
You're probably hearing the compresser kicking on and off. My old car I could always tell when the compressor kicked in because it made the car louder and caused a slight vibration. In the TSX however, I can't really tell when it kicks in. Maybe you should mention it to the dealer.
Driver/Detailer
At high fan speeds, the fan bearing noise is irritating! Only started happening after 1.5 years.
Quote:
nope. even at 1 I can hear the compressor. I'll ask the dealer about it.Originally Posted by Grifter
are you running it at full blast?
Quote:
Yeah!!! That's what it probably is but on mine I do hear the compressor. I'll ask the dealer about it. Thanks.Originally Posted by derbaff
Registered Car Nut
Quote:
I have that in my 1998 Path. The compressor makes a noise, which I've been thinking sounds like a bearing gone bad... I don't hear a thing on my TSX though. The only thing I'll ever hear/feel is that the engine idle speed will go up a couple of hundred revs to handle the extra load of the compressor. Have it checked out, this doesn't sound normal at all! Originally Posted by derbaff
